Question about Kenmore 93142 Gas Dryer
Kenmore dryer sounds like flat tire
My Dryer sounds like it has a flat tire...Everytime the drum makes a rotation it sounds like the drum is slamming down. Is there a possibility that it is out of balance? I leveled it but the noise continued. I believe the model number is 87042/97042 that is what is on the manual.
  • 370 Answers
Take the top and front off your dryer and check the front drum slides. The top slide usually wears out.
Posted on Nov 17, 2008
Hi, I have a Kenmore Elite dryer model 110.76962501. It was working fine earlier in the day. Now when I turn it on, it makes a humming, whirring sound. The drum is still rotating. Any suggestions?
Hi etzelmueller...
I think you have a drum roller problem or a felt seal problem on your dryer to cause the noise you describe..
Please take time to rate me.
Sep 18, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
The dryer is making a thump/thud noise as the drum turns. The dryer works fine but the noise sounds like something hitting everytime the drum goes around. Could this be the belt going out?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 02, 2011 | Kenmore 83142 Electric Dryer
I have a Kenmore 80 series dryer model number 110.76832501 and the drum is off balance, creating a noise similar to a washer that is heavier on one side. When I rotate the drum, it seems to be grinding in...
Check the rollers in the back of the machine. It sounds like you have a flat spot on one of them. Here is a link to the part in case you need it.
Happy Holidays The FixYa Team
Dec 23, 2010 | Kenmore 800 7983 Dryer
Drum will not rotate
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 25, 2010 | Kenmore 83142 Electric Dryer
Dryer makes a sound as if there's a marble loose in some rotating part. It doesn't seem to be coming from the drum, because when I disconnect the band from the motor and hand rotated the drum at speed...
heatman101
ghhgfhf
Mar 21, 2010 | Kenmore Elite HE3 Steam 8676 Dryer
Kenmore dryer Drum not rotating
check the belt,it might have slid off of pulley,make sure smooth side of belt is facing up,ridges should be touching drum
Nov 25, 2009 | Kenmore Dryers
Thumping sound from loose drum
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 10, 2009 | LG DLE5977 Electric Dryer
Drum seems to be loose. Metal to metal sound each time it rotates
the rear bearing is bad and maybe also the glides on the felt need to be replace they sell it as a kit
Aug 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore dryer
most likely it is the blower wheel i have seen alot of postings layely and when i took mine apart and found the blower wheel i could tell right away that was the problem
Aug 31, 2008 | Kenmore 63942 Dryer
Constant "thumping" sound when dryer is going
you can fix it by ordering a whirlpool roller kit but its no big deal the drum sits on rubber rollers when it just sits the rolers get flat spots on them like tires and makes the thumping sounds its just noisey but no big deal but they do make a kit with softer rollers
May 24, 2008 | Kenmore 63942 Dryer
Kenmore 93142 Gas Dryer Logo
195 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
