Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Ti 84 plus SE is detected on computer but cant get status, keeps
Ive re-connected it many times and i have let it rest or whatever, it just wont connect anymore, pretty new too.
  • Anonymous Dec 31, 2008
    that happens to me too
  • snacks tasty May 11, 2010
    Does ti connect recognize it and such? Sometimes it recognizes it but you can't interact with the calc. This is ussualy fixed by restarting your computer, for some reason it works.
5 Suggested Answers
  • 4 Answers
SOURCE: Divice Not Found
i had the same problem, it can be fixed by using another cord as ArmyDrummer said, or try connecting to a differnt usb port
Posted on Feb 22, 2008
SOURCE: how to restore applications on TI-84 Plus Calculator
Go onto www.education.ti.com, find the downloads column, and click on apps and operating systems. Then you can click on the different lists and find out which apps you accidentally deleted. You do this by (after clicking on it) looking under the "Pre-Loaded On" column. If you find the name of your calculator there, this is one application that was deleted. Hope this helps!
Posted on Aug 05, 2008
  • 8 Answers
SOURCE: ti 84 plus silver edition language change
ON, Apps, scroll down until you see English, press enter. There might br several language choices there...Dutch, French, etc...
Even try: 2nd, mem, 7, 1, 2, enter to reset all RAM.
Posted on Nov 11, 2008
rockitman187
  • 2559 Answers
SOURCE: Can't find the % button on TI-84 plus :(
Just hit the 2ND key and the 0 (catalog key)scroll down to percentage or just divide the answer by 100.
Please rate this a fixya
Posted on Feb 13, 2009
  • 21 Answers
SOURCE: TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
Posted on Mar 02, 2009
My TI-84 plus silver edition calculator is not responding. Whenever I press a button it takes forever to put it up on the screen or it doesn't work at all! I need some serious help with this. I tried...
Hi purzabumafu8,
You need to re-install the Ti 84 Plus OS on both calculators, ASAP!!! You can fix these problems by installing the newest Ti 84 Plus 2.55v. MP OS, operating system. Use fresh batteries.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the USB or, IO link ports. Then they can send you a copy of their OS, while you receive it on your Ti 84 Plus. Hopefully, your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work. Link the two calculator together through the USB or, IO link ports with the proper cable. If don't have another reliable calculator to connect too, you'll have to connect the calculator to a computer to download the OS, goto Procedure 5. If your downloading off another calculator goto Procedure 1.
Important Note: Never disconnect a TI Connectivity Cable during a transfer. Lost of power during installation of OS will destroy your calculator.
Procedure1. Procedure to linking to another calculator.
On their calculator press, [2nd][Link][G] [Right-Arrow]. On your calculator press, [2nd] [Link] [Right-Arrow] [Enter] and, then press [ENTER] on their calculator too. Their calculator should say, "TRANSMIT" and, your's will say "Receiving." Then on both calculators once transfer is complete press, [2nd][MODE] to quit and, return to the Home screen. If the OS was transferred then your finished with these procedures. If your calculator won't turn on or, is locked up try the Procedure 2, below.
Procedure 2.
Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". If calculator did not turn on or, is still locked up goto Procedure 3, unless already did Procedure 3, then goto Procedure 4. If you calculator does come on and is responding and, your connect to another calculator goto Procedure 1. If you calculator does come on and is responding and, your connect to a computer goto Procedure 7.
Procedure 3.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. Goto Procedure 2.
Procedure 4.
If the above process did not work. Try re-doing the Procedure 2, and, this time extend the time in Procedure 3, by 5 minutes to 10 minutes before you put all the batteries back in the calculator. These calculators can be a little stubborn at times so, keep trying Procedure 2.
Procedure 5.
If you can't find a calculator to connect too, you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS.
Procedure 6. Procedure to installing the latest Ti84 Plus 2.55v. MP OS. TI OSDownloader does not always install the latest OS.
You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed. If your calculator will not turn on or, is locked up goto Procedure 2. Or else goto Procedure 7.
Procedure 7.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install. Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
Jan 17, 2011 | Texas Instruments TI-84 Plus Silver...
My TI-84 calculator lost its cover for the batteries. Since then it sometimes can't turn on or show anything when I push the button "on". But sometimes it still can work. But because I havent...
Hi twylazhangzh,
Sound like your Ti 84 Plus is really over loaded and, can't function properly. You can fix that by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84 Plus. Hopefully your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer just keep following my instructions below.
First, you need to download and, install Ti Connect to your computer. If you don't need any help installing Ti Connect goto Procedure 1.
If your computer's OS is XP or Mac and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my XP or Mac OS". Just follow Procedure 1 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
If your computer's OS is Windows 7 and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my Windows 7 OS". Just follow Procedure 3 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
Procedure 1 to installing Ti84 Plus 2.55v. MP OS
1). You can also get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, the Ti Device window should pop up and, highlight the port when found that your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
Jan 12, 2011 | Texas Instruments TI-84 Plus Calculator
I jus bought a TI-84. when i turned it on it said RAM cleared. now there's a blinker on the screen. every time i press a button, nothing happens. whats wrong with this brad new calculator
You need to re-install or, update the Ti 84 Plus OS. Since you just bought the calculator it is unusual that it is already to that point of clearing the RAM. You can connect a computer and your Ti 84 calculator together once you downloaded and, installed Ti Connect software on the computer. That way you can use the Ti OS Downloader that comes with Ti Connect software to install the newest Ti 84 Plus OS. Or, if you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84.
Get this problem fixed as quick as you can. You do not want your OS to fail any more than what it already has. If you can not find another calculator to connect too, then you can connect through your computer. You may have a long road ahead of you getting the Ti Connect software and, drivers working right. Just remember to come back to your posting here and, post a comment of what ever is failing. This will notify me right away and, I'll walk you though it if necessary.
When ever i turn on my ti-84, it says waiting..... PLease install operating system now.
Hi biancaaii,
You need to re-install the Ti 84 Plus OS, ASAP!!! You can fix the problem by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS. Be careful, even a power failure during the process of installing the OS will destory your calculator.
Procedure 1 to installing the latest Ti84 Plus 2.55v. MP OS
1). You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
When i press most buttons it gives me the message ERR:MEMORY i cant access memory so i cant reset ram or delete . also i can not connect to my cpu it says TI-84 plus Silver Edition detected, but couldn't...
From the TI knowledge base and FAQ
How do I correct ERR: MEMORY on a TI-83 family or TI-84 Plus family graphing calculator?
An ERR: MEMORY is given when there is not enough memory to perform the instruction or function. To increase available memory by deleting the contents of any variable (real or complex number, list, matrix, Y= variable, program, Apps, AppVars, picture, graph database, or string), follow these steps. • Press [2nd] [MEM] to display the MEMORY menu.
• Press 2: Mem Mgmt/Del.
• Select a variable or data that needs to be deleted and press [ENTER].
• Use the arrow keys to move the cursor next to the item, and then press [DEL]. The variable or data should now be deleted from the memory.
When deleting programs or Apps, a message asking for confirmation will appear. Select 2:Yes to continue. To leave any variable screen without deleting anything, press [2nd] [MODE].
Notes:
With the exemption of programs and Apps, no warning will be given to verify the deletion.Some system variables, such as the last-answer variable Ans and the statistical variable RegEQ, cannot be deleted.
Hope it helps.
Oct 06, 2009 | Texas Instruments TI-84 Plus Silver...
My computer doesn't find my calculator
Install the TIConnect software on the computer.
Execute TIconnect. Connect the calculator to the computer through the USB cable or the TI Silvercable. Turn calculator ON.
In TiConnect main window, click the icon TIDeviceInfo. A small window opens. If the result is NOT FOUND, click on communication settings. Select the devive :Ti 84 Plus SE
Select cable type : USB or TISilverCable,
Select Port : Should be USB1
Click OK
If that does not work, try calc-to-calc connection with a working calculator.
Hope it helps.
Sep 23, 2009 | Texas Instruments TI-84 Plus Calculator
Ti-84 problem!
Could be that your calculator needs to be reset. Take out the internal battery that is located in a tiny door with a screw right above the 4 AAA batteries. Leave this out for about 8 hours and put it back in. Put in the AAA batteries and the calculator will be reset and may work.
Aug 02, 2009 | Texas Instruments TI-84 Plus Calculator
Wont turn on after 2 buttons
try to connect it to the computer and reboot it
Sep 10, 2008 | Texas Instruments TI-84 Plus Calculator
TI 84 Won't basically wont istall correctly
maybe because you don't have the ti connect installed.
Sep 01, 2008 | Texas Instruments TI-84 Plus Calculator
Uploading From Computer
Are you using TI Connect or TI GRAPH LINK ?
Aug 03, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
291 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
