Question about Nokia N70 Cellular Phone
N70 ME charging problem
I plug the charger to my N70 ME, the indicator goes up as usual charging, but what surprise me is that the battery (and the indicator) stay low (if I charge in 3 of 7 bar, then it'll stay in third bar after hours of charging)
I'm a technician as well, so I know the probability of battery and charger problem, so I have switch it with other battery and other charger. Problem still occur. I have replace the charging connector as well because it's somehow broken (probably the person before, plugged the charger port hardly). But yeah problem still occur,
I know that some are software problem (which in this case I doubt, because I measure the battery Volt meter and it stay same), so I hard format it with pressing *,3,green call and on-off switch at same time. Guess what? after format, all stay same.. Seemed to be charging, but level of battery stay low.
I use desktop charger (the one that only charge battery without plugging to phone), and it works, my battery level increase..
So what hardware problem possible do you think??
FYI i use v 5.0737.3.0.1 RM84 (which i think everybody use and never complain such weird problem)
  • m681990 Dec 25, 2008
    I've the same as this problem .
pal707
  • 31 Answers
SOURCE: Nokia 6681 continous restart
its uem problem or viruse problem virus problem can be sold by formating card and phone bhoth but if problem countinui its very hard to repair this kind of problem
Posted on Oct 09, 2008
  • 51 Answers
SOURCE: losses its battery charge within 3-4 hours
hi
you changes the batteries and reprogaraming the mobile in this whole mean while did you use the same charger if yes so you porably charge your mobile with the another one because you said the battery became hot is only becase of the voltage may be the charger capcitor lose their power to store the voltage so you just check the another charger.
thanks
your friend from fixya!
Posted on Oct 26, 2008
johnychel
  • 796 Answers
SOURCE: N70 Unlock code
if the security code was manually set by you,then there is no way to find that with imei or serial number...
reinstalling the phone software is the only way
thankyou
Posted on Jan 06, 2009
  • 110 Answers
SOURCE: i want to unlock the phone SECURITY CODE
here is a site where you can unlock all nokia handset in any operators
www.gsmliberty.net/shop/nokia_unlock.php
Posted on Mar 17, 2009
VinayT
  • 1884 Answers
SOURCE: forget my loke code.switch off
Friend, You have made the biggest mistake by forgetting the code. Now the only answer is to get the firmware re-installed and not use code in future. Get it done thru Nokia Care.
Posted on Aug 25, 2009
Headset won't recharge battery must be dead
That may very well be the case. There is a finite number of charge / discharge cycles a battery can handle. This number varies based on the level of discharge prior to charging, temperature, etc. Some devices can operate via charger alone - and others require a small amount of battery power and a charger to operate. A classic tell tale sign is an older device that has been used regularly and charged every day or night - but was allowed to fully discharge once - due to failure to connect to the charger. Attempting to charge may indicate it is accepting a charge but goes completely dead / dark when the charger is removed. That usually indicates a battery that was drained so low that it will need to be replaced. Good luck!
Oct 19, 2015 | Radio Communications
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
My charger has been plugged in but the battery is not charging. i have an acer aspire 5740 laptop
me too the same... When I plugged in the charger the power indicator shows battery in charged 100% when I removes it goes to 0%.. I installed ubuntu on acer 5740..
Aug 31, 2010 | Computers & Internet
My mobile n70 not stand on charge above 3 to 4 hours
This problem is usually caused by battery but on rare conditions the charger as well. First of all, try with another battery (your friends' or..) and keep it charging for 1 hour and see the result, Second try with another charger. If the problem still persists then there might be problem with charging ic which you can't fix it if you are not a mobile technician. Give it a try and good luck..
May 05, 2010 | Nokia N70 Cellular Phone
Nokia n70 charger will not enterphone pin
Hi
Be sure that you are plugging in the right charger because some Nokia chargers are not compatible with the N70..
Also be sure that you are plugging the charger into the right port,The charging port of the N70 is the smallest hole under the phone.
Cheers
Mar 28, 2010 | Nokia N70 Cellular Phone
Usually the red light is on to indacate the batteries are being charged,now the green is the only light that is on
The green light on the charger usually indicates that the batteries are fully charged and you are ready to go. Does the controller show the batteries are fully charged? Can you operate the power wheel chair for several hours? If so, you are good to go.
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced.
Dec 20, 2009 | NRS Hoveround MPV 5 - Used Power...
N70 not charging
try replacing the charger or the charging point.
Nov 17, 2009 | Nokia N70 Cellular Phone
My N70 is not charging when i connect to power.But it shows the charging indication. what can I do?
you might have problems with the battery.try to watch if the batetery is standing good or is cxorectly putted in the device or your charger might have some problems on electonical part.Or the wire from your charger or entrerupt on a part and dosn't charge only when you put hem in a position.
Mar 07, 2009 | Nokia N70 Smartphone
My L6 i motorola/ charcoal color phn
have the firmware reflash on the phone and that will take care of the issue...you are having
Feb 11, 2008 | Motorola Mobility L6 Cellular Phone
Nokia N70 Cellular Phone Logo
52 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
