Question about Durabrand W600 Shelf System
Cd door won't open
How can I open the door to remove the disk it doesn't make any noise when I push the open and it doesn"t play
  • 165 Answers
Hello try this disconnect from ac outlet wait 1 or 2 mins and before you connect again push the power button hold it and connect see what happnes...you problem actually lies on faulty switch door....saludos
Posted on Nov 18, 2008
I have a Dell Inspiron 1525 with a cd in disk drive. The door will open but disk won't come out. What do I need to do to remove it?
The CD is loose in the drive. You need to remove the CD drive from the computer and then remove the metal case off the drive then you can remove the CD. Put the metal case back on the drive and install the CD drive back into the computer.
Mar 21, 2013 | Dell Inspiron 1525 Laptop
Cds won't play
OK, your discription of your problem is rather vague.
Do they try to play but skip or make god awful noises? Or do you have no audio at all?
If they are skipping check to make sure there are no smudges on the underside of the CD. If so clean them with a soft cloth,
Sometimes severe scratches can cas the same problem. You can buff out some scratched using tooth paste or you can by a scratch remover that they sell in stores (it is a gadget that will clean and buff out some scratches available in many stores).
If you have any of the label missing then this is a worse issue. It is actually the top of a CD that you need to be most careful about scratching because if you remove the laquer that protects the silver layer of the CD it will remove part of the silver with it along with any audio or data that is on it. There is no repair for this.
If you have ruled out a damaged or dirty CD then be sure you are not trying to play a CD that has data files intended for computers on a player that cannot open them. The best way to do this is to check the CD on a computer and open the drive folder and view the contents of the disk. Files such as MP3, WAV, WMA and others will not play on a standard CD player. If the files are CDA that is a standard audio CD formatting. So next see if the disk plays on the computer.
If the CD plays on a computer then return to the CD player and attemp playing again. Make sure that the player recognizes the CD being in the tray. Also, verify, if you can that the CD is spinning within the player when you play. If the CD is not spinning or the player does not recognize rge disk try a disk you know to be undamaged.
If you still have problems then you will have to have your player repaired or replace it.
Sep 12, 2012 | Audio Players & Recorders
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Emachine disk door want open
I'm assuming the CD drive door is stuck and won't open. You will see a small hole in front of the drive. Take a pin and insert it in the hole and push it. The drive should open up.
May 05, 2011 | E-Machines e15t 15" Flat Panel LCD Monitor
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
Cd does not spin
the motor will need to be replaced
Apr 15, 2009 | Fisher SLIM-1500 CD Shelf System
Cd Stuck
Look at the "door" or "flap" of the cd rom drive. You should see a small round hole. If you straighten out a paper clip and insert it in the hole, push in gently, that will open the door and eject the disk. Please rate this if it helped you.
Jan 17, 2009 | HP Media Center m7060n PC Desktop
Dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
Jun 18, 2008 | HP (176135-630) (176135630) Internal 48x...
Durabrand W600 Shelf System Logo
97 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Jonathon summesfield
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
