Question about Brother MFC3240 Multifunction InkJet Printer
How to use scanner of Brother MFC-6490CW?
I. Need to know how I can scan to FTP.ii. Need to know how I can scan to file, so itautomatically converts to a pdf, not jpg.
iii. Need to know how I can scan multiple files, so thatthey are converted into 1 multiple-page file and not a separate file for.
iv. Need to know how the scan detects a 11 x 17 sheet onthe scan glass and scans it to that size and not just 8.5 x 11.
I want the answer by today evening.
Thanks,
Karina Abrams
I have a MFC-6490CW and when i scan A3 it cuts off the sides of the page when i scan to file
Hi
Please select the auto select paper size option, if this don't fix your problem then go the paper option and manually select the A3 paper size and scan.
Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
I want to disable the Brother MFC 6490CW LED lamps to scan in transmission mode rather than reflectance mode. I want to wire in a switch so the under glass illumination LEDs are going on the inbuilt...
The problem is a hardware issue.
I have the same unit and would love to know how to solve this short of applying opaque tape over the lights
Maybe a repair tech with a troubleshooting guide would know which pin would disable the lights, they'd be trying to enable them.
The second problem is that people don't read the question before posting a software solution.
May 30, 2011 | Brother MFC 6490CW InkJet Printer
Printer/scanner won't work
Should just be 1 disk for the install. Go to your devices and make sure your printer is plugged in to the power and to the computer. Click on add a printer, select add a local printer, and the computer should scan and recognize your plugged in printer and install it again. If your computer doesn't see the device, check your cable.
Mar 31, 2010 | Brother MFC 6490CW InkJet Printer
I have a Brother MFC-6490CW and I want to scan paper that is 11x17 and the manual says that i have to set my glass size. However, they say to push the Scan button and then the Scan to Media button...that...
You will need to open the control center program which is installed when you install the printer on your computer.
Start, all programs, Brother, control center. Click on configuration then scan then file. There are two tabs at the top, change the paper size at bottom of each to ledger and press ok.
Dec 13, 2009 | Brother MFC 6490CW InkJet Printer
How do i reset my scanner on the brother mfc-6490cw all-in-one printer/scannner/fax so i can scan in legal size documents? now i can only scan in letter size.
Launch scanning utility from computer instead of using the scan button on the Brother. Tha will give you more options. You also may need to configure the Brother software settings.
Aug 10, 2009 | Office Equipment & Supplies
MCF 6490CW SCAN AS A PDF
I was trying to figure out how to scan multi-page documents to a single file and found this on the Brother website:
Double-click on the ControlCenter3 icon located in the Task Tray to launch the program window.
Click on CONFIGURATION -> SCAN.
Choose the type of scan you require. The choices are: IMAGE,
E-MAIL, and FILE.
The Scan to configuration window will appear.
The SOFTWARE BUTTON tab configures the Scan to button within theControlCenter3 software interface. The DEVICE BUTTON tab configures the Scan to key on the Brother machine. Choose the tab you want to configure.
Under FILE TYPE select an option that allows multi-page documents:
a) PDF (*.PDF)
b) Tiff Multi-Page # Uncompressed (*.tif)
c) Tiff Multi-Page # Compressed (*.tif)
Click OK.
Apr 28, 2009 | Brother MFC 6490CW InkJet Printer
Unable to scan to email with gmail on a Brother MFC-6490CW
Use SMTP relaying. Set up a computer with SMTP relaying. Go into the Remote Setup Program for your Brother MFC and select Setup Server. Use the IP address of that PC in the Server Settings and set Auth for SMTP to None. Worked great for me. This document can help you set it up on the relaying computer/server. http://www.lesolsoncompany.com/InstantKB20/Attachment17.aspx
Apr 01, 2009 | Brother MFC 6490CW InkJet Printer
Brother MFC-7840W Printerwill only give me Scan To FTP option now
i had the same issue - was previously able to scan to a number of different formats, then switched modems, providers and then only the scan to ftp option came up.
took me about an hour to figure out the solution, but now it works
for windows users: * go to your control panel * go to the scanners & cameras section * your printer/scanner should show up here * right click on it and select 'properties' * select the network settings tab and then -- enter in the correct ip address here OR -- specify your machine by name (enter in name here)
hope this helps!
Jan 18, 2009 | Brother MFC 7840W Printer
1,778 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
