Laptop screen flickered, went grey and now won't come on
The laptop screen flickered a few times and went grey. It then shutdown. When it was rebooted, it worked for a short time then went grey again. Subsequent reboots failed to bring the screen back to life, even though the lights on the keyboard started up.
I've found a recall notice for the laptop, but I'm outside the 24 month warranty by 121 days. The same notice suggested that if you haven't experienced a problem yet, then they have a bios update that adjusts the fan algorythm.
HP technical suggested that it's possibly a video card problem and since it's part of the motherboard, the entire board will require replacement.
I was hoping that a repair could be completed, but don't know where to turn. Is HP the best option, or should I try a local repair shop? I recall an HP PC problem that I had previously, and HP wanted me to scrub the hard-drive before sending the unit to them.
Either way, do you think that the video card be repaired? Do you have any idea what a repair would cost (replacement or repair)?
Thanks in advance!
  • donb33 Nov 19, 2008
    Thanks for the suggestions. This was very helpful.
  • 32,281 Answers
The video chip is on the motherboard, would not be cost effective to replace, and the motherboard replacement would not be cheap. Get a quote first, they could charge for a quote and then offset it against the repair cost should you go ahead.
I suggest that you put the money towards a new laptop, it would be better, faster, than your old one.
You can use your old laptop for parts.
Remove the hard drive and place it into an external USB hard drive case, to use as an external data or backup drive. Use the RAM to increase the memory capacity of your new laptop.
Posted on Nov 17, 2008
Phoenix securecore tiano setup
I would take it back to where you bought it to be honest bennet. Sounds as though something went wrong on the setup and you will probably have to shutdown the EFI. Let the place where you bought it take care of it.
Jul 03, 2013 | Computers & Internet
Every time i turn on my laptop the screen goes grey and white.
plz reinstall window vista for sove the problem
it is due to virus
May 09, 2010 | Microsoft Windows Vista Home Premium with...
Acer Aspire Screen Strange unique Flicker
Yup well I am sorry to inform you but your screen is in fail mode this is a typical thing we see all the time...the "Driver IC's" are going flaky. It's the pixels turning red & grey that tips one off....
Feb 18, 2010 | Acer Aspire 6930-6455 Notebook PC
Flickering of the screen
just open the system and reseat the display cable...
Sep 20, 2009 | Acer Extensa 5420-5687 Notebook
"Flickering" screen
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 15, 2009 | Toshiba Satellite A105 Notebook
Hp Laptop screen flicker
I am sure that the issue is related to the cable that connects to the LCD Display or the LCD Backlight.
There should be some connection shortage because of which the LCD flickers few times as stated by dan231.
I Recommend you to get the Notebook examined as soon as possible before something really goes wrong...
Dec 05, 2008 | HP Pavilion dv6000z Notebook
Screen Flickering on Acer 3680-2682
Ok we must remember when we setup any device on our PC, one of the many non PnP devices is and LCD Monitor, your PC should always be shutdown before installing a new Monitor. If you did not do this you could have damaged the I/O port on your PC. Not a definite, but possible! When you plug up a monitor or any serial cable while the PC is still on, it is of a low voltage which can casue some issues for you! Sounds like this one is yours!
Nov 21, 2007 | Acer Aspire 3680 Laptop
My laptop screen is flickering
That could be ths connector that connect the LCD to the Motherboard in the laptop. Ive seen something similiar wherein i took down the screen, cleaned up the connectors and it worked like new...... for a few weeks then it went back and started he flickering again. We finally fixed the problem by replacing the screen. Apparently the connector behind the screen was giving trouble. Have someone check the cable from your LCD to the board but I think you might need to fix the connector or replace the LCD screen. Regards, babb
Apr 19, 2007 | Evesham Voyager 5800 Notebook
Computers & Internet Logo
333 people viewed this question
David Payne
David Payne
