Question about Acer Aspire 5580 Notebook
ASpire 5580 series, no power
I have aspire 5580 series laptop. the battery is charging but it doesnt turn on. I have tried using good known power cables but still fail. I powering it with battery, but nothing happen, no hdd spinning or any sound from my laptop. I tried removing the batterry, powered it with the power cable alone and still no good. I did also, tried to swing, reseat power cable but it doesnt help. pls help me. U can email me dha.aliman@gmail.com. thank you
    Scholar:
  • 111 Answers
Hi Dhadha,
Try this: - remove AC adapter plug - remove the battery - insert the battery again. - try power up the laptop.
I have same problem, but this trick always work, and I always do this every power up. :)
However, I am using a usb optical mouse for an indicator. When inserting the battery, I check the light on the mouse. If it is flashing the second I insert the battery, then the power up will be successful. IF it is not, then remove and insert the battery again.
Try it.
Regards,
Dapid Candra
Posted on Dec 08, 2008
My acer laptop aspire 5580 creen monitor goes black, how can i put it back?
Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot. It worked for me! Just shutdown, put the battery back in you're good to go. Worked for me so definitely worth a try.
Jun 11, 2012 | Acer Aspire 5580 Notebook
It just wont turn on i have checked the power lead and its ok its an acer aspire 5050 laptop
Hi. I would suggest you double check the ac adapter if the powercord is properly attach to it ot also you might want to try powerdraining or powercycling your computer. To do this you must turn off your laptop then remove the battery and unplug the ac adapter then press and hold the power button for 20 seconds while the battery and ac adapter is out, after that place back the battery and plugin the ac adapter and try turning on your laptop, if this doesnt work then try power draining it again and just use the ac adapter or just plug it in without the battery then try again turning it on. If it still has the power issue then try a known good ac adapter so that you could double check that it is not an ac adapter issue or a battery issue. If all that trouble shooting step doesnt work then you could also try calling acer tech support to help you on your issue if your machine or laptop is still under warranty they would help you fix it by sending that laptop to there depot without any charge. Hope this Helps
Jun 09, 2010 | Acer Aspire 5050-3242 Notebook
I have the Acer 5580. It does not seem to be
Sounds like bad news. It's not good to continue using a wiggly port. You'll likely have to have a technician look at it.
May 12, 2010 | Acer Aspire 5580 Notebook
My acer aspire 3680-2022 series does not store charge for 1 hour
Try replacing the battery with a known good one one and if it still doesn't charge up properly then you know the battery is bad
Aug 21, 2009 | Acer Computers & Internet
I want a driver of battery for my acer aspire 5610z please
hi try this http://support.acer-euro.com/drivers/notebook/as_5610z.html
Jun 11, 2009 | Acer Computers & Internet
Acer aspire 5570 no power
This problem usually occurs if your laptop undergoes any shock or it falls.
The processor of the laptop hangs and needs to b reprogramed by experts in service center.
Same problem happened to my Toshiba A100
Don't forget to rate my solution Plzzzz...
Nov 17, 2008 | Acer Aspire 5580 Notebook
Acer Aspire 5580 poor battery
Its time for a new battery. After a period of time of using a battery, the amount of charge it can hold depletes. Even if you always have it plugged in. Usually, batteries only last 18-24 months which is sad, seeing how much they cost. I'm a computer tech and see this problem everyday first hand. The best thing you can do is buy a battery from eBay and save yourself a bunch of money. Local retail stores charge up to 3 times as much for a battery. Good luck and I hope this helps..... :>)
May 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5580 wont power up at all
try to run it without the battery and see how that fares?
May 03, 2008 | Computers & Internet
Acer aspire 5580 laptop unable to power up fully
remove battery and use the ac try it then, if that doesn't work remove everything possible cdrom,memory,battery,pc1.gif cards and try it again, if still fails try wiggling the ac cord at the input
Jan 24, 2008 | Acer Aspire 5580 Notebook
Acer Aspire 5580 Notebook Logo
130 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
