I am having trouble connecting the phillips adsl wireless base station sna 6500 , i get to the end where you put your settings in to be saved and cant save the setting , after speaking to my i.s.p to check all settings are correct that i typed in ,they told me i have to conntact you as the adsl base will have to be configured ... how do i do that ? many thanx . e. tatler
SOURCE: problems setting up Belkin wireless G+ mimo modem router/usb network adapter
I keep losing connection to internet. I have comcast rca modem with belkin wireless g router. HELP???
SOURCE: configuration settings for the zoom x6
When connected to your local network, open your browser and type in 10.0.0.2 and hit enter. A password screen will appear - type in "admin" for the username and "zoomadsl" for the password (without inverted commas).
Click "basic setup" then click "start" which will configure your settings. If it says it can't configure them, turn off your anti-virus and firewall then try again. If it still doesn't work set the protocol to "PPPoE" and VPI to "0" and VCI to "38" then type in your username and password you received from your ISP. Remember your username is an e-mail address so should end in "[email protected]" i.e [email protected], [email protected] etc.
Then click "write settings to flash" and wait for a ridiculously long time. Your internet light may flash green then disappear then go red for ages but eventually (providing you have entered your correct ISP details) it will come on.
SOURCE: can't connect to 10.0.0.2
Googling that address will get you nothing. There are specific blocks of IP addresses that are not used on the internet. Instead, they are reserved for use in private networks. The addresses in these ranges are not available for use on the internet:
Class A networks: 10.0.0.0 - 10.255.255.255
Class B networks: 172.16.0.0 - 172.31.255.255
Class C networks: 192.168.0.0 - 192.168.255.255
What they are telling you to connect to is your DSL router which must be using the 10.0.0.2 address for it's own web-based configuration tool. If you open up your web browser and type http://10.0.0.2 into the address bar and hit enter, it should bring you to their configuration utility that is built into the router.
SOURCE: adsl modem giving very slow and intermittent internet connection
this is not a problem with ur PC or router this could be in the Filter or splitter that ur ISP gave you, what i would do is call ur ISP and have them run a line test that could be the reason
i work for att. and that does happen ALOT you can also go to
www.speakeasy.net go to the bottom you should see whats my speed or test ur speed click on that and select a server closest to you and it will run a speed test up and download speed
good luck ,
July
