Artifacts on monitor
I have a nVidia 8600GT and it was connected to my monitor (VGA to DVI converter) and to my TV via s-video.
Irecently replaced the TV and unplugged the s-video cable from the backof the TV with the computer still on. Now my screen looks like thisONLY when I get to the login screen on Windows and ONLY when I amlogged into Ubuntu (boot screen looks fine on both OS)
I tried uninstalling drivers and reinstalling. Also tried removing and reinserting the card. No success.
I have reverted back to the on-board video and it works fine.... did I break my video card?
Screenshot: http://i35.tinypic.com/29zu6o3.png
  • 981 Answers
Ha.  Trippy bg and woven look.   It seems it's only like this in certain video modes, so I expect what happened was not that electrical damage happened from incaution with cables but that a DDR3 line came unsoldered when the S-Video socket was manipulated.  You can either sport around on the video card looking for the line by applying a q-tip with deionized water around the memory chips, just lightly squeeze the memory chips back into place...reflowing solder on the card, maybe.      Come to think of it, maybe there's a signal that S-Video is connected that did disaffect the line-scan circuitry to fail in that regular way; you can also try biasing elements of that connector's hook-up to the card (or just a longer cable, or a video switch) to see if that affects visual quality.
     Good job debugging your situation.  I hope the card goes back right with mere re-flexing.
Posted on Nov 21, 2008
  • 849 Answers
Two possibilities
either drivers files gone bad or
the card gone bad.
try the card on other computer
Posted on Nov 17, 2008
How do I convert a Westinghouse 22" LCM-22w3 DVI/VGA LCD Monitor into an HDTV?
Dear Amy,
Normally, monitors do not have tuning electronics for capturing TV signals.
Therefore, consider the monitor as a "dumb" unit that only displays information coming from your computer. Also, this unit does not have a HDMI input, but only VGA.
So, you are fated to have this monitor connected to your computer, always.
Now, you may find good software that will "tune" the TV signals from streaming at the Internet and show whatever is being broadcast. The same way you can access YouTube and watch videos these TV tuners will get the streaming signals the TV stations send via Internet (not all do that) and watch the channel in your PC/monitor
Since I do not have additional information about the computer you use I cannot give you other ideas
I hope I have helped you.
May 18, 2014 | Westinghouse 22" LCM-22w3 DVI/VGA LCD...
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
Hi there basically I have two ports on my monitor dvi and vga and dvi is connected with another appliance so that leaves me vga but when I connect my vga to my desktop the computer is on but there is no...
try with DVI port and see it works or not.
if worked buy a converting port (DVI to vga) and connect you video card Via DVI
and connect your other appliance Via VGA port by that converter.
Jan 09, 2011 | Computers & Internet
Trying to get 2 monitors working
plug your LG display into the DVI port and the BENQ into the VGA? it may just be a random compatability error.
May 04, 2010 | XFX NVIDIA GeForce 8600 Graphics Card
My samsung syncmaster 2233sw shows multiple displayes when i take it to its max res. i use win xp sp2 and have nvidia 8600gt gfx card. the monitor works well on lower res but only shows this problem when i...
Typically this is a driver issue on the host (PC) side. DVI or VGA connection? Update the video driver. Some video drivers (especially older laptops) can't correctly send that resolution.
Jun 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Phillips 40" lcd Connect my pc via DVI
This most likely means that your lcd doesn't support the resolution that your laptop is displaying.
Feb 23, 2009 | Toshiba Satellite Pro M15-S405 Notebook
Nvidia GeForce 7200 GS PCIE - Multi-Display does not work
This card does not allow you to Multi-Display with the VGA port and the S-video port. If you put a DVI to VGA port adaptor (not supplied) on the DVI port, you can Mulit-Display two VGA monitors and (presumably) a VGA (from the DVI port) and S-video monitor.
This is not explained anywhere and the card does not come with a DVI to VGA port adaptor, so I wa only able to work this out after I bought the DVI to VGA port adaptor.
May 21, 2008 | Nvidia GeForce 7200 Graphic Card
No signal
Weegee, Unfortunately you are trying to mix two different video types: VGA is an analog video interface found on most computers (except for latest with flat panel monitors, which are usually DVI). Your TV DVI interface is digital (although there is a DVI-A, which is an anlog DVI interface, it is unlikely that your TV has this). So, what you are trying to do probably won't work. I assume your computer does not have DVI output (otherwise you wouldn't have bought the adapter), but some monitors have VGA inputs; does yours? What kind of DVI adapter did you get? Is a DVI-A? Check out http://en.wikipedia.org/wiki/Dvi for info on DVI interfaces.
May 12, 2007 | iLO 3200 32 in. LCD Television
Dual monitor problem
I think you may have to use tv out as the secondary monitor
Oct 31, 2006 | Gigabyte GV-NX62TC256 GeForce 6200, (256...
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
