Question about Canon PowerShot S5 IS Digital Camera
Timer I found out how to set the timer...but can't quite get how to trigger it...make it go off...
  • 48 Answers
If you refer to the owners manual it will tell you how to use the camera.
Once you have set the self timer, you press the shutter release button to start the count down
Posted on Nov 17, 2008
DWSR483EAWW GE Dryer doesn't turn off when set to "Optimum Dry"
Does the timer advance to the end or does it stop advancing in the middle of the cycle?
If the unit does advance to the end on timed but it won't advance on auto, that means your cycling thermostat isn't triggering. First, make sure your vent is cleaned and the best way to do that is just run a cycle without the vent hose connected to the back of the dryer to see if things change. If your dryer still won't dry properly, then the cycling thermostat will need to be replaced because it's not cycling properly.
Try it on the timed cycle. If it doesn't advance, then you have a bad timer and the timer will need to be replaced.
The cycling thermostat is mounted to the front of the blower wheel housing.
Here is the timer if it is found bad.
Here is the cycling thermostat if it is bad.
Keep me posted!
Nov 30, 2012 | Dryers
Timer T104 triggers can't move
Problem is not identified.
Copy following link to troubleshoot T104 timer:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Dec 21, 2011 | Intermatic Hardware & Accessories
Grundig TV turns itself on
Remove power for a day and see if the processor resets. It seems to be only due to the timer as the TV can be triggered only from the internal timer to power ON.Try and reset all the timer settings , switch power off completely and it must cancel all settings.
Dec 12, 2011 | Televison & Video
I have aMicromark MM9533 7day electronic timer (could be quite old), but cannot set it because I have lost my instructions. I can set the time ok, but when I try to set each day's on/off times, it...
There are eight timer on/off events, you set each of the on and off time pairs for a particular day of the week or combination of days. If it is that old, mine was bought in 1999 and just rediscovered, you should change the button battery found under the screw panel. The timer doesn't work the way you seem to be describing.
Sep 02, 2011 | Vacuums
I have a n older mandolyn (upm.??) AX-801S timer. I have it all programmed. However whereas many timers have ON/AUTO/OFF settings this one only has ON/OFF. Does anyone know which way to set this timer to...
I do not know that timer.
Many older timers never had online manuals.
Check following 2 links to see if your timer and manual show:
http://waterheatertimer.org/UPM-timers-and-manuals.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 22, 2010 | UPM Indoor Electronic Programmable Plug-In...
How to set self timer?
The self timer is indicated on the display with a clock type indication. It is circular arrow with a central arrow inside the circular indicating the timer.
Find this out from the menu. most of the camera have it with button seperately that can be pressed to set off the presetted time. This time can be set accordingly ... to your spacing.
Check this out and trigger the timer to set the camera ticking to click.
Aug 27, 2010 | Cameras
My pool's Dial Time Switch won't trip "off" anymore. After killing the power to my timer for a couple of days to drain/refill my pool, I turned it back on and all was working well (but the time and day...
Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX ON EBAY
TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ. .. VOTE PLEASE THANKS... JAY
Jul 15, 2009 | Intermatic T104 24h 208-277v Mechanical...
Electric Intermatic T171 THE MOTOR IS NOT RUNNING
Insure the motor wires are hooked to the line in and nuetral posts of the timer. If they are and the timer can be triggered manually then the motor is burned out. If the timer cannot be triggered manually check the breakers at your electrcal panel to see if the one of them may be tripped that supplies the power to the timer.
Good Luck
Dec 03, 2008 | Electric Intermatic T171 24 HOURS 40 AMPS...
Freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Sep 06, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Canon PowerShot S5 IS Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
