Question about RCA 32F530T 32" TV
TV won't turn on
I just bought my tv 3 yrs ago then all of a sudden it just went died. Everytime i plugged the power its making a annoying sounds and the power button on the tv wont even turn on. Can u tell me if is this fixable...
  • 1 more comment
  • procomtech Nov 20, 2007
  • Cailloux Dec 12, 2007
    Starting problem Dead TV. RCA 32F530T, chassis ATC113CD4. I Replace flyback # 257807 along with the H-O/P XSTR (2SC5148).
    > Problem fix. Everything work fine, except i have hatching or tearing lines at one or two places on the screen depending on the white level (contrast), always in half screen area on the top. Same symptom with video and RF input.
    >I replace the flyback 3 times with different part # (not original RCA flyback) and suppliers, 257807, 257805 and ACME-2632 (replacement for RCA #261163). Still have exactly the same problem with 2 tv set. I checked parts in the horizontal and vertical circuit, DC supply, everything looks good.
    Additional info: RCA 32F530T TV year 2004 (not 32F531T).
    Original RCA flyback NLA. Use original Horiz output transistor Toshiba 2sc5148.
    If i lower the vertical height, tearing lines disappear. No error code in service mode.
    Any suggestion? Bulletin note?
    Someone saw that before?
    Thanks
    Pierre
  • GON1976 May 23, 2008
    PICTURE WENT BLANK I TURNED IT OFF AND TURNED IT BACK AND NOW THE TV WON'T TURN ON BUT THE POWER LIGHT IS ON
    Problem Solver:
  • 5 Answers
32F530TCD4
I received this solution:
"This was apparently caused by using replacement flybacks. Add a .001uf cap (102k@2kv) from RL03 (the side away from the FBT) to ground. This will shift the picture a little then compensate a little with parameter 15."
In my case, i used an other flyback the HR8934 from Diemen to get a more stable picture without blooming, and add a 440pF (two 220pF capacitor in parallel) instead of .001uf to eliminate the tearing lines.TV won't turn on - bfde541.jpgac61dec.jpgdda8fac.jpg.
Posted on Mar 25, 2008
Compare you epom settings in the service mode if you don't have them in the service manual./st.
I've owned for approx 3 yrs. Today I was watching a show on my Panasonic TH-50PZ80U and all the sudden the sound went away. From the lowest volume setting to the highest, no noise at all...Please...
Hello!
First move: unplug your broadcast provider's box, wait for a minute, then plug it back into power source. I mean: leave all the connections intact, just unplug from power source. It might be just power cord or power adapter. If that's not the case, please do the same with TV. Unplug it from wall outlet, wait a minute, plug it back in. It's a next step, if your "box" won't take care of the problem. If that won't take care of the issue, refer to owner's manual for "reset" procedure. Worst case scenario: you might need to replace main board inside or your TV.
good luck,
Thanks,
Alex.
Oct 09, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Hello my name is Amy & I have a 50 inch toshiba dlp (56hm66). I have no lights on or power. It's completely dead!!! I read the manual & followed everything about the lamp, how to restart, made...
Tv have no power at all?U already check the source?Yes,most likely the tv DM power supply board is dead or could be anythings on the highvoltage deflection circuitries on the tv.Check the DM power supply board like for dying or dead capacitors and circuit fuse breaker.Have no skills to do this call and get an estamate by tv Tech. to get it fix.
Jan 13, 2011 | Toshiba 50HM66 52" Television
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
TV won't turn on.
The buzzing sound could be due to either a bad filter capacitor in the power supply or a shorted component further down the line keeping the power supply from running at the correct frequency.
Jan 12, 2008 | Sylvania 6427FF TV
TV doesnt have a picture but power button flashes
I have a suggestion you need to check the regulator if you have a mutitester it would be this is a job for a technician .
Nov 29, 2007 | Sony KV-32S26 32" TV
Closed caption always comes on when I turn on TV!
Same thing here!!!!! It is soooooo annoying! Can't do it from the TV and the CC does not turn it off either.
Any suggestions would be so appreciated.
Sep 12, 2007 | Philips 25PS40S 25" TV
Television will not turn on
My 47" Vizio wouldnt turn on this morning.....had a similair problem 3 yrs ago.....this is what i did and fixed the problem myself.....apparently you have to reset TV. Here is what has worked for me. So unplug tv power cord from the tv. Hold the power button and imput button together ( located on side panel ) for approx 45 sec......plug cord back into tv. Press power button on tv and voila !!!!! Tv came back on!!! I have had my Vizio almost 5 yrs. But have to call the unhelpful customer service atleast once a year.... I hope this works for you :)
May 03, 2007 | Vizio L32 32 in. LCD HDTV
Open Questions:
RCA 32F530T 32" TV Logo
302 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
