Question about IBM ThinkPad T30 2366 Notebook
Delpart I downloaded delpart and will put on cd and try it,,will I have to reload bios ? and where can I get them from ? If i gonna wipe clean and try things I want to make sure I have everything I need or might need ahead of time. Right now when I boot up I get a black screen saying error loading operating system
    Welcome Back:
    Visited the website for 2 consecutive days.
This seems to me more on OS or hard drive issue then Bios.
delpart however wont affect the bios
If you need to update your bios. Once you installed your OS you can download the latest bios from the IBM support site below:
Posted on Dec 03, 2008
My friend bought a laptop (Acer Aspire 4520) when you turn it on you get a black scre en with a blue box that says Enter Password. I was able to find two bios passwords online that will take you to the...
That's the idea of HDD passwords. You can't access the data on it at all. Either by boot cd or physically removing the hard drive and connecting it to another pc, you still won't be able to access the drive. Two options, replace the hard drive and reload a clean o/s. Or, there is a service available that might remove the password and retain the data. There are also services that will remove the password and wipe the data, as a security measure. But at the cost of either of these services, makes better sense to replace the drive and reload the o/s. You can goole HDD Unlock and find the software easily. You would need to connect the drive to another working pc. Download and run the software on that password protected drive. It will tell you if it is unlockable. To bad it's not a Dell, I may be able to provide you with a p/w to unlock it.
Oct 15, 2013 | Acer Aspire 4520-5582 Notebook
HP recovery partition wiped, and unrecoverable, ..............need an image reload it, once reloaded not sure if it is recognized by bios.
If you didn't make a set of recovery dvd's or cd's when you first bought your machine, then you can purchase a set by going to the HP site with your serial number, model, etc.
Apr 04, 2017 | HP Pavilion DV9910US Notebook
Hp zd7168cl- began locking up, slow responses, auto reboot, error 0000008, attempted to reload os-xp- will not respond or reload- attempted to wipe drive with killdisk-not responding. it ran great before-...
ok go into your bios by selecting one of the following:
F1 or F2 or Delete the computer will go into bios.
in bios look to upper left cornner you will see load defaults you will click on load default . then you will need to look along the top to where it says boot options. in boot options you will need to select the cd rom as your first boot option. if you look along the rite hand side it will tell u how to move and select your option. now you will need to put the harddrive as the second boot option. now you will need to look along to where it says exit. now you want to save and exit the bios . now try reboot your system. and selct F8 for advance options. in advance options you want to boot the l{ast known good configuration}.
if that fails you are setup to boot from cd-rom first so your bootable disk should work.
Nov 19, 2009 | HP ZD7168CL Notebook
My toshiba 7220cte will not load a fresh win 2ooo os , fdisked and formatted drive. tried loading from cd and floppy disk. at very end of install. unit shuts down , and states i have an invalid disk in...
If you have an invalid disk in the unit, is the floppy disk left in the disk drive.
However, to completely erase windows, fdisk and format does not work.
Download delpart.exe and use this utility. Be careful though. When delparting a laptop, make sure not to delete the small partitions, but only the ones that are NTFS.
However, if the laptop has a SATA hard drive, this method will not work unless you create a bootup script with delpart.exe to run automatically. Then it will work.
If you have any issue, blog it on the internet about the exact procedure to create an iso bootable disk to load delpart.exe.
Aug 09, 2009 | Toshiba Portege 7220CTe (PP722U-7D90Q) PC...
Leopard OS
Is the hard drive SATA or IDE. On IDE, I know you can use delpart. Locate a SATA tool to wipe the partition of SATA drives. Install LEOPARD as usual then after rebooting.
Jul 25, 2009 | Apple Power Mac G5 Desktop
How to format a Toshiba M100
get a win 98 boot disk floppy. set bios to read floppy or usb floppy first save and exit. insert disk and boot comp. select boot without cd rom support. At command prompt type " FDISK " then hit enter dont type quotes. delete the particians then create new partician set 1 particians as active then remove disk then insert OS disk and go forth. I after you install your new OS and you get two boot options at the command promt after loading type " delpart " and delete the particians and save (use the tab and alt keys to bring up menus save and exit before you leave delpart) reboot and run fdisk to creat a partician and set it as active. then load your OS
Jun 10, 2009 | Toshiba Satellite M100 Notebook
Cannot reinstall new os seems my hard drive has been block by some kind of protection
If you are install xp to a computer that had vista or has a sata hard drive.The SATA drivers must be loaded during setup.If this is not the case,Please post back with more details.
May 16, 2009 | Acer Aspire M1640 Refurbished Intel...
Wiped clean cannot reload windows
Are you using a floppy or a disc? Your CD rom or disk may be faulty. If you have another copy and/or another cd rom drive try that. Also reseat the memory sticks. Lastly it all of this fails your hard drive may be the culprit...
Apr 20, 2009 | Acer Power FH PC Desktop
New Laptop
The laptop has an eRcovery partition the will restore it to original condition.
Acer eRecovery
At the Acer splash screen, you can press Alt and F10 (at the same time you would press F2 to enter the BIOS) to bring up a DOS style version of eRecovery.
· The unit is able to reload Windows from this mode faster then from CD.
· The password by default is 000000 (6 zeros) and it is displayed when you are asked for the password.
· Users are able to change the password in this mode for eRecovery only.
· The system can recover from the hidden image on the hard drive (PQService partition) or from CD/DVD media.
· It is possible to reload from the factory style CDs/DVD or the snapshots that the Windows version of eRecovery creates.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 14, 2008 | Acer TravelMate 2300 Notebook
T30 wont reformat
download "hirens boot cd" and burn to a cd, select the machine to boot from cd, when boot cd loads, select boot cd, it will take you into a dos menu, select hard drive tools, there are a number of utilities there for you perform surface scans a bad sector checks and repair tools
good luck with it
Nov 17, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
