Question about IBM ThinkPad T40 2373 Notebook
Battery indicator on even after turn off the laptop
Battery is charging and system works fine. but after shutting down the system, battery indicator stay on and battery drains out. Mine is an IBM thinkpad R50e - 1834-U2G
    Scholar:
  • 121 Answers
Reset the battery.....remove battery from system...boot while your adapter is plugged on....shut down..reinstall the battery......
if this doesn't help..
go to Control Panel>>>>>>Power Options and view setting ..........what does the system do after being switched off options
keep me posted
Cheers
Posted on Nov 17, 2008
How long have u got to charge it for for 1st use because I charge it all day when I turn it on the next day the battery kept going down I'm still charging it
A new battery comes charged well enough to start the car, if it keeps going flat u have a problem either with the charging system or a power drain, so once car is turned off sonthing is staying on draing the battery. Or the battery could be faulty but very unlikely. To check the charging start car and put a volt meter on the terminals of the battery should be reading aprox 14.2 v if it only reads 12 something then u have a charging fault. If charging fine then have to test for a power drain and the easiest way to do that is to open bonnet or boot depend where battery is lock the vehicle up and wait about 20 mins for the car to shut down Ecus etc remove earth terminal off battery and put a 12v bulb from the earth terminal of battery and the earth lead if the light shines u have a power drain remove each fuse in turn remember to put it back after until light goes out then u have the offending circuit. Hope this helps
Jan 23, 2015 | Cars & Trucks
Is it the alternator?
Sounds like a charging system problem. The engine runs off of the alternator but if it is not charging the battery properly the battery will be drained until I engine will no longer run. You need to get the vehicle to a repair shop to have the battery and charging system check for defects
Jul 15, 2014 | 2004 Nissan Maxima
2000 pathfinder battery draining
Sounds like your alternator is doing nothing-the car is running only off the battery. Have your charging system checked-does your battery light stay lit? If that bulb is burnt out, that may be why the charging system is not working. On some charging systems, that bulb is crucial for the alternator to work.
Engine off, a fully charged battery should measure 12.5 volts with a voltmeter. Engine idling, and the voltmeter at the same battery should be showing about 13.5 volts. This tells you the charging system is working.
May 13, 2017 | 2000 Nissan Pathfinder
Charging system not working,we have replaced the alternator,the starter the fan sensor,the heat sensor replaced the battery several times car will not stay charged been told it was the electric module that...
No such thing. If you have a new battery, and the alternator's testing fine then there's obviously something draining the battery.
You'll need a multimeter for this. First off, once started, test the battery voltage at idle. Then increase RPM to about 2000. The idle reading could be as low as 10 Volt(since you just put a massive drain on the battery but should pick up with RPM to aboout 13 Volt at least. It could even go up to 14 Volt.
If that is fine, shut down. Disconnect the neg pole on the battery. Switch your multimetre to Amps(You may have to move one of the meter wires to a current measuring connection on the meter.) Connect the leads between the neg of the battery and the cable that came off it. A reading any larger than 0.5 amps (500mA) could mean trouble. First thing I always check for is trunk and glove compartment lights. They may not be turning off with the lid closed. Next is aftermarket amplifiers. If incorrectly installed it does not shut down and drains the battery in no time at all.
Jul 09, 2010 | 1993 Volkswagen Fox
Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Jun 23, 2010 | Lenovo IdeaPad Y510 Notebook
Laptop would start up but shut down immediately and the battery w
How long does it stay on for? I had a similar problem. Mine would stay on for 10min then shut down. It ended up being an excessive build-up of dust around the cooling fan. If your problem is similar its worth taking a look at. Good luck, Todd
Dec 22, 2009 | Toshiba Satellite A25-S207 Notebook
I have an IBM think pad T40 that does absolutely nothing when I try to turn it on. It's actually my daughters, she sid it was working just fine then she shut it down and when she came back an hour later it...
Try taking the batter out and booting using just the power cord and Vice Versus'. Also when the power is plugged in does the charging light (Battery Indicator) blink or light up? If you know the Power Supply is good, then the Mother Board may have fried. If it's under warranty, take the Hard Drive out and send it in.
Dec 20, 2009 | IBM ThinkPad T40 2373 Notebook
Battery and alternator charging problem
As dumb as this may sound check the termials and if the u-shape is up then flip it over. I had the same thing happen to me on mine and now it works fine.
May 08, 2009 | 1997 Lincoln Continental
Ibm thinkpad t30 will not start
You should charge the battery longer about four hours. Then the light should be green. Try. If that don't work disconnect the battery and check for anything. Connect your battery again and take a look. If it still isn't functioning please let me know.
Dec 25, 2008 | IBM ThinkPad T30 2366 Notebook
Discharges battery after being turned off.
The battery light on a notebook only uses .07 volts to light up and very minnium current.Your battery light isnt discharging your battery.Something called internal resistance is what is discharging your battery.If you are gonna park your notebook for a while and not use it. Take the battery out of the notebook. You will experence less battery drain . But a battery that is getting old may have drain even when not installed in the notebook.Try running the battery compleatly out of juce then charge it 24 hours then do this several times in some battery types this will help them hold a charge better. I hope I have been some help I own Kips Computer Service in Hattiesburg,MS. My e mail is pinebeltrecords2@aol.com feel free to e mail
Nov 08, 2007 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
211 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
