Question about Samsung MW1030WA Microwave Oven
UPDATE: GE Spacemaker XL1800 Microwave
Alright...The microwave workes fine. But when i operate the unit, the turntable doesn't turn and the microwave starts making this raspy sound. I have to manually turn the rotating button off so it stoppes making the noise. What can I do to fix it? ____________________________________________________________ You wanted the Model # JVM1850BD 002. I hope this helps.
  • venkatvijaya May 11, 2010
    Are there any parts betwee motor and coupler. Coupler is not broken.
    Turntable rotates with a jerky motion. When I called GE service center they said it could be bearing or something between motor and coupler.
  • Anonymous Mar 26, 2014
    The microwave starting popping sounds and now does not heat. Ally other parts of the microwave work, it rotates, makes noise etc
  • Samsung Master
  • 9,149 Answers
JVM1850BD002 is a correct model number. This is a GE made by Samsung. It sounds like the motor or coupler is bad. More likely the motor. If you grab the motor shaft and try to gently turn it, it may grind or slip a lot. That's a sign of a bad motor. If the coupler is bad, it will be cracked or broken, causing it to slip on the motor shaft or the turntable itself. The coupler is reference 40, and the motor is reference 43 on this handy exploded view drawing: http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00016500/00016593.p01.pdf (copy & paste whole URL) Here is the GE part price info on these two parts: DESCRIPTION DRAWING PART NO. PRICE MOTOR-SYNCHRONOUS 43 WB26X10038 $46.00 COUPLER 40 WB06X10144 $8.75 If the motor is bad, you might be able to find the Samsung part number printed on the motor label and look it up at http://www.samsungparts.com They often have parts for far less than the expensive GE parts.
Posted on Dec 04, 2006
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
GE Spacemaker XL1800 (jvm1850sh06) problem
Use a hair blow dryer to dry out the underside of the microwave. After you are convinced that it is dry you may operate it again.
That said, if it still is acting up read this:
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Aug 06, 2009 | Microwave Ovens
GE Spacemaker XL1800 does not heat. All other functions appear to be working normally, the light comes on and the turntable functions. When turned on, it makes a humming noise slightly louder than normal,...
Possible bad heating element, You should remove the cover of the unit and look at the heating element with the power off. Until you get your problem resolved I would recommend not to even turn it on due to the fact that you are unsure what is going on and you smelt some burnt smell. Just for safety until you fine the problem
Feb 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
you need to replace the motor turntable, that will cost you around 30 bucks...its not easy to disassemble the unit you nee to send this to a shop im afraid
cheers
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My ge profile spacemaker xl1800 turntable stopped it turns once in a while. What do I need to replace. Where can I find the part number?
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Your turntable motor is shot. It's simple to remove and replace. you don't even have to take the microwave out of the shelf. To remove it take out seven screw around the perimeter of the bottom. Lift up on back of bottom to get over clips on the back. Remove the two screws holding the motor in and detach the plug. Find a electrical repair shop for you make pick it up and replace it. When replacing it take out plate and hold plate key down and align flat side of shaft on motor with the plate key.
Nov 30, 2006 | Samsung MW1030WA Microwave Oven
Samsung MW1030WA Microwave Oven Logo
267 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Simon Flummox
Simon Flummox
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
