Maytag Epic-Z F-24 error code. Randomly got this error code and it's not in the book. Any ideas?
  • Anonymous Apr 20, 2009
SOURCE: Maytag Epic Z frontloader Error Code
i also have a magtag epic z &f 24 error code is on my washer. i don't know what to do.
Posted on Aug 24, 2008
  • 3 Answers
SOURCE: maytag epic z washer flashes
I had the same problem and the code f01 would flash, I could select the wash and make selections with all the other buttons but once I pushed start it would flash f01. I fixed the problem by not turning the machine off and pulling the power cord out of the wall and it seemed to reset it. I could immediately turn the machine on and it stared working.
Posted on Jul 23, 2008
ngfam1
  • 639 Answers
SOURCE: Maytag Epic-Z F-28 error code
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Try unplugging the machine for 3 minutes and then rebooting it!
If the problem continues! Service is the only possibility
If your in the states try A&E Factory service the 800 number is below! They are usually quick!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
sivaranjini
  • 241 Answers
SOURCE: Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Posted on Jun 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: maytag epic mfw 9800TQ0 Will not wash, error code
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
How expensive is it to have a technician repair my Maytag Epic Z dryer with an F-01 error code? I know that the error code is a bad control board.
FIXYA has no idea of labor charges from Maytag service and they do not tell us if asked probably depends a lot on where you live.
Sep 15, 2017 | Maytag Dryers
I have a Maytag Epic Z400T. Front panel goes completely dark with a slight click when START button is depressed. F-24 error code present with no other codes. Temp sensor NTC ohms out at approximately 10...
Possible that there is problem with the power supply to your main board unit, It is possible that the DC converter is having a low regulation and so when the start is pressed on there is a drain on the power resulting in the panel showing a DIM. Check the motor, remove power and check for overload to motor and inlet and drain pump
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
Suds and F02 Error codes.
You did all the right thing, now it could be the control panel
Mar 29, 2013 | Maytag EPIC MFW9600S
Maytag epic II washer error codes, especially error code F 21
HI. Click here to download the complete service manual for this unit. All the repair procedures and error code definitions can be found in this repair manual. I would advise to save this PDF to your HD for safe keeping.
May 02, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Code f-24 is flashin on my washer
I had the same issue, called Maytag they didn't know what the code meant, said it was one that a technician had to come out and diagnose but was probably power related (glitch or outage). I hit cancel twice and it cleared and I went on with the wash with no further incident.
Jul 12, 2009 | Maytag EPICz Electric Dryer
Jun 22, 2009 | Maytag EPIC MFW9700S Front Load Washer
"Maytag Epic z washer flashes f 24 error code"
I have a maytag epic z dryer and it wont turn on. it worked fine the last load, now nothing? help.
Apr 25, 2009 | Maytag EPICz Electric Dryer
Maytag Epic Z frontloader Error Code F20 Help Please!!!
Jul 01, 2008 | Maytag Washing Machines
Maytag Epic Z error code
I need a clear code for maytag epic z front load washer
code f-o1 is coming up
says intall new ccu, I did but still the same
do I need to clear the code if so how.
please tell me.
Jun 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
924 people viewed this question
Top Washing Machines Experts
