Question about Sony Handycam DCR-TRV103 Digital Camcorder
Playback Problems Hi, I have this Sony Digital8 camera and I am having problems with playback. This happens with 99% of my tapes. Most of the tapes are hi8 tapes and recorded in digital format. The problem is basically a jittering or a little skipping of pixels with an image, kind of a scrambling of pixels. The sound will also skip. It's hard to explain, so I put a little video on google's video that show a little scene and you can see what's going on. I would really appreciate any help with that. Thanks so much the video is here http://www.youtube.com/watch?v=CV_Y4NtGkRs
  • 1 more comment
  • Peter Bellville Dec 17, 2007
    Same problem here with skipping jitters both audio and sound which suggests to me a problem with the tape itself or a slipping drive mechanism. I haven't figured out a way to fix it. At times, the problem goes away and all returns to normal. I am using old tapes and perhaps they get stiff or something. I am still experimenting.
  • Same Problem Jan 01, 2008
    I have the same problem when tring to replay some older (i.e., 5 years old) tapes which I recorded using the same camera.  But if I record something now and play it back, I do not have the same issue.  Hence, I suspect that it is a tape problem rather than a camera problem.  Have you experienced he same thing?
  • pamaassa Nov 09, 2008
    when I playback video, it skips
Ditto. Old tapes seem to be related to the problem. All I have to do is put in a new tape, play it, remove it, put the old one back in and it will play normally again. I can't explain why. I know the camera has an automatic tape detection feature and I wonder if it is at fault. Perhaps the camera has trouble detecting older tapes and the brains get scrambled. A new tape resets the detector. It's just a guess.
Posted on Jan 10, 2008
Check this link out www.alamocameraservice.com
Posted on Jan 06, 2008
2 Suggested Answers
quang123
  • 107 Answers
SOURCE: Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Posted on Dec 04, 2008
Can I use Hi8/Digital8 NTSC tapes in my DCR_TRV250E?If so would I be able to playback recorded tapes on the UK televisions?.
DCR-TRV250E is a PAL version camera of the Digital8 format.
Yes you can use Hi8/Digital8 NTSC tapes. The camera will record a PAL digital picture on the tapes which means that you can play back the tapes in PAL and therefore you will be able to playback recorded tapes on UK televisions because they are also of the PAL format.
Oct 10, 2009 | Sony Handycam DCR-TRV250E Digital...
Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Aug 18, 2007 | Sony Handycam CCD-TRV37 Camcorder
Cannot playback digital8 tapes on sony dcr-trv250
dear
you need nt worry for that , i want to ask u between these 9 year how many time does you get your camcorder serviced ...like you go for bike or car.
so, i would like to tell u that the symptoms which you are telling are related to the problem in tape path of the camcorder ,nothing more then that ,audio breaks and video glitches are their which is the problem, you can contact me for any kind of further help.
take your camcorder to near by service centre as it would nt be possible for u to align the tape path as we need CRO and other jigs and tools for aligning the tape path .
Jun 28, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Aug 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Hi,My Sony digital8 dcr-trv140e is playing back in black & white this has only just happened other wise the camcorder is fine
If you are playing NTSC signal format cassette in your camera (model number shows it is PAL camera) picture result might be in B/W. go to camera player menu and select NTSC playback on PAL tv. Color will be there.
Jun 07, 2008 | Cameras
Sony TRV460 D8-->Hi8 switching
I too was having a problem playing back my 8mm in my TRV460. The audio and video was both very glitchy. I tried what dyz66 said and rewound to the start of the tape,and then recorded about 10 seconds of meaninless video. After that the whole tape played nice and clear. Thanks for the idea. I believe from here on out I'm going to buy some new tapes to try and avoid this.
Apr 29, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Playback
Recording and playing a new tape worked for me too. Thanks!
Mar 17, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
Playback *stops* on tapes where I used Aux input to record
It could be that.. you generally want a timebase corrector to properly record from analog tape to some other medium. But maybe not. Most tape-based devices also include a tension sensor, to detect the end-of-tape. If you're using tapes that are too old, cheap, etc. it could be that you're seeing this triggered.
I recommend trying the same VHS recording with a good quality, fresh tape. If it's still kicking off, you at least know it's due to the camcorder having issues with sync or something on the tape. If it works, blame the old tapes.
It's probably camcorder dependent, but I have done tape restorations using Digital8 and DV equipment, and have never known a camcorder to cut itself off due to dropouts or other problems on the tape -- mine just play through. So I think it's at least possible that it's just the tape.
Jan 20, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Sony Camcorder playback problem
mechanical alignment! try to record for a minute and playback the result on another player/recorder, not on your camera, if the playback is not okay then your camera needs alignment, you need pro fix. You said that you've done manual cleaning already, maybe you dis aligned the mechanical parts accidentally, applying too much force on the mechanical parts of your small unit tends to bend, dislocate or move these parts out of alignment. defective videohead will never playback good video, and you said that it seems to correct only a few minutes of playback.
Sep 13, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam DCR-TRV103 Digital Camcorder Logo
505 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
