Question about GE Energy Star WCVH6260F Front Load Washer
Clothes are too wet at the end of the washing cycle
At the end of the washing cycle, clothes are too wet.
  • Anonymous Nov 23, 2008
    Same issue, clothes are wet @ end of wash cycle. Washer not running through spin cycle.
  • Anonymous Mar 22, 2014
    w3240 miele wet after cycle
  • 725 Answers
Washer is not spinning out ..
first check your drain pump there is a coin trap .Under the front panel. remove the three screws and you can clean it out
Posted on Nov 17, 2008
Have a kenmore washer and I have to run everything thru 2 spins cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn clutch.
Oct 25, 2011 | Kenmore 22422 Top Load Washer
My washer spins out very slowly and the water drains but the clothes are very wet.
f the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing.
Nov 30, 2010 | Westinghouse WWS833ES Super Capacity Top...
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
My clothes are soak and wet after the spinning cycle ends
Could be a gearcase problem or a motor coupler problem or a clutch problem .Best off to call a reputable service company such as Sears.
Feb 06, 2010 | Washing Machines
Clothes are very wet after cycle run
how to use this kind of washing machine awg372?
Jan 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
517 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
