Question about AEG B1180-4 Electric Single Oven
Need replacement Dial knobs on Oven
AEG Electric single Oven. Competence 824 B
1- Need a replacement Timer Bell Rubber push button knob
1- Need a replacement clock setting button
  • dougyvonne Nov 20, 2008
    Thankyou your advice lead me along a trail that has helped me top locate a local service crowd who located two secondhand parts.
    Regards
    Happy Seeker
  • AEG Master
  • 3,463 Answers
Look in yellew pages for a Zanussi dealer, you will need mod number,,serial number, and er number, all of which are on the rating plate found at the front of the oven.
Posted on Nov 17, 2008
  • Barry Coates
    Barry Coates Nov 20, 2008
    Glad to hear you got fixed up.
I have an AEG Competence Single oven model B2100-1-w The oven is not reaching or holding temperature I have noticed the fan is not spinning
Hi steve sounds like your fan motor is faulty they are not very powerful any resistance in the bearings can stop it starting. oiling the bearings wont help you need to replace the motor also it will have damaged the element no air circulating it will of overheated. an overheated element usually lasts till xmas morning.
Nov 09, 2010 | AEG U3100-4 Electric Double Oven
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
http://www.espares.co.uk/part/cookers-and-hobs/thermostats/aeg/p/1604/143/0/0/1061574/top-oven-thermostat.html
May 20, 2010 | Ovens
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
Need to know how to use the timer
The manual for this Oven is available free to download at http://www.safemanuals.com Regards Vortash
Apr 28, 2009 | AEG B3101-4 Electric Single Oven
Removed dial knobs, put back on oven doesn't work
possibilities are that the spindle retaining clip is missing giving the impression that the oven thermostat is being turned when infact it i s slipping, or the oven is in auto mode if timer model.
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
Clock settings
press 1st and third buttons together. use rhs button to set time and it should then work
Jul 13, 2008 | AEG B1180-4 Electric Single Oven
Aeg competence b 8139-4-m - oven not heating up
your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
from sid
Apr 20, 2008 | AEG B2100-4 Electric Single Oven
AEG B1180-4 Electric Single Oven Logo
407 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
