Question about Kitchen Ranges
Miele Oven H316 When using fan forced the area behind the back plate where the fan is glows very red. If stop fan forced cooking and revert to normal conventional heating red glow does not appear. Fan operates and no red glow. Oven is 5 years old.
    President:
  • 1,462 Answers
Element should glow dull red when on fan oven but not bright red. are you sure fan is operating? remember there are two fans - oven fan and casing fan and you may be listening to casing fan
Posted on Nov 17, 2008
Is the fan on my oven broken or just needs cleaned?
It is most likely coated in grease, remove it and clean it first.
Mar 08, 2018 | Ovens
I have a Belling DB4 90Ei Cooker and I have noticed a hole in the back of each oven. Why is this
Your oven is fan assisted and that is the fan you can see behind the slots. Air is drawn into those slots and the fan forces air to circulate from the side of the oven. In recipes you need to reduce your temperatures by 10'C and your cook times by 10%. The fan gives very even cooking with no hot spots in the oven. This particularly useful baking cakes. I am a chef :>)
Sep 14, 2016 | Belling DB4 90EI Gloss Black 900 mm...
Water dripping into fridge from freezer. noticed red hot element in back of freezer behind vent inside freezer
Heater glow behind frz back wall is normal during auto defrost cycle. This happens about 2 or 3 times a day for approximately 30 to 45 minutes. The water migrating into the fresh food section could be from a blocked drain tube which should be be in the area directly under the red glow you noticed. Should be a hole going through the floor into the drain pan under the refrigerator. Force hot water down hole until it flows freely.
Apr 07, 2015 | Refrigerators
Both oven lights blown and fan not working
If you've noticed that your oven is not heating up, there could be a problem with your oven fan thermostat.
its simple to check :
1.
Open oven door and locate the back plate, which can be found at the rear
of the appliance. Remove the back plate from the oven fan (it should be held in place by between two and six screws). The oven fan is located behind the back plate.
2.
Examine the oven fan element and the fan blades (they are exposed once the back plate has been removed). If there are noticeable signs of burning, blowing, bulging or splitting in an area of the oven fan, you can tell where the problem is coming from. It is also common for there to be no visible signs of a problem. This allows you to determine whether or not the oven fan can be replaced from inside, or if it is necessary to enter the back of the appliance.
3.
Remove screws from element and disconnect wires if screw heads are showing. This is commonly the case, as it is unusual to have to further disassemble the oven. After the screws are removed, the element becomes detached from the oven. Use caution to not accidentally pull out electrical wires that are connected to the element.
4.
Take the rear cover off, which is held in place by multiple screws. After that, you should be able to see the wiring harness, fan motor and the components of oven fan element. Parts of the fan element are near the round fan motor, which is located at the center of the oven. There are two electrical connections and one earth wire. Take note of the location that the earth wire is placed, because it needs to be restored to the same position.
5.
Remove the oven fan element. Check the element again for obvious signs of damage. If there are no apparent markings, check the oven with an electrical test meter or a continuity tester. After replacing oven fan element, return all connections and covers to their original positions.
This should help you up to an extent to check it in case of any assistance please revert back.
Jun 10, 2011 | Microwave Ovens
I have a six month old Miele oven - H5140/5240 BP - not sure which. It smells atrocious after it has been on for an hour or so, whether on conventional on fan forced cooking. really disappointing, and a...
when the oven etc is new it will make a smell. put the oven on the hotest temp and open a window to burn off the oil grease used when the oven was fitted, then when it cools down give it a good wipe round inside with some oven cleaner then the smell should be gone.
Jan 04, 2018 | Miele Novotronic H350-2B Electric Single...
I saw sparks? or small flame on back wall behind fan inside oven
It sounds likely that the fan motor is faulty,more so if the oven is heating to some extent.
You should be able to see or hear if the fan is working or not
Hope this helps with your prob.
Nov 26, 2009 | Gaggenau EB 270/271 Electric Single Oven
Instruction manual
HI SIR
When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
Multifunction Oven Function Selections
2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
8. Fan-assisted Baking or Patisserie Setting
 - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
top
Advanced Oven Features
Cavity Cooling
The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
Triple Reflective Door Glazing
Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
Wipe Clean Enamel (Extra Optional)
Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
Drop Down Grill Element (Extra Optional)
The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
top
The Electronic Timer
Normal Baking
Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
top
Fan Forced Baking
Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
top
Grilling
Function 5 & 6: During grilling the door may remain closed or completely open.
This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
Sep 11, 2008 | Ovens
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Kitchen Ranges Logo
304 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
