Question about Kenmore 24 in. 16259 / 16254 / 16252 Built-in Dishwasher
Brand new 16254- blinking LED, nothing happened
I just got the Kenmore 16254 from sears, after hooked everything, and checked everything on the list without no problem. After I plug in the power, only Hi-Temp & Heat Only LEDs flashing/ blinking, and nothing happened when I press any other options, Start/Cacel. Only thing I can stop blinking is either open the door or unplug the power. The plumber guy said it is the dishwasher problem. I search Internet, no one had same problem that I have so far, any suggestions about this problem or suggestions about the dishwasher? Thanks!! LW
  • 2 more comments
  • Anonymous Jan 18, 2008
    Having same problem with blinking LED. Have not found the cause. Does not happen on every wash.
  • emonnetiii Jan 21, 2008
    I am also having the same problem. I called Kenmore, but they said that they can't come out until the first week of February! I am pretty disappointed that it will take that long. It seems like something that they could troubleshoot over the phone. I also submitted a question online to the Kenmore experts. Once I hear something, I will post here.
  • 2drty4u Jan 25, 2008
    I am having the same problem. Dishwasher is about 7 months old.
    no solution..posted to the wrong spot
Temprary solution is to press both Hi-Temp and Strart. The washer will go through test cycles and finish. The next time it will work fine. This is a intermittent problem. No final solution yet.
Posted on Mar 27, 2008
Mine is a model 16259
Posted on Jan 25, 2008
  • 2drty4u Mar 28, 2008
    I had a repair man come out from Sears and it turned out that it wasnt sending power to the heat element. It would run sometimes non stop other times it would run for a few minutes and then the lights would blink. He replaced the control module and it seems to be fine now......They also said that sometimes the problem is that the hotwater heater isnt set high enough.. He said it takes 20 minutes to raise the temperture 1 degree. He said to make sure the hotwater heater is set to at least 120 degrees and to run the hot water to get it in the pipes before I start the dishwasher..
Insignia ns-55l260a13 does not power on. Power led blinks 5 shorts, pause, 2 shorts and stays on. Screen blinks and nothing else happens afterwards.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 23, 2016 | Ideal Sales New Insigniatm - 55 Class -...
When turning on my technika it has a red flashing light but nothing else happens when I press the remote that came with it.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 01, 2015 | Televison & Video
My Kenmore 20722(990) washing machine stopped mid cycle. It is full of water and clothes. I checked my circuit breaker, nothing tripped. I checked my ground fault switch, that wasn't it either. It is...
Go to the link below and enter your model number in the search window there. Sears has thousands of parts lists and line drawing illustrations that can aid in finding the reset button if present or any other part you may want to locate or replace.
Sears PartsDirect
BTW, it does not have to be a Kenmore or Sears-branded appliance. They have many others as well.
Mar 22, 2011 | Kenmore 20722
Blinking on learning indicator...push the remote or wall button nothing works...what happen?
If that LED is blinking a code let me know what it is. For instance 5 blinks and a pause then repeats. If it is just blinking randomly that is normal.
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Nothing is happening
I used the eternal last resort: Banging repeatedly on the control panel!
Jan 30, 2009 | Kenmore 24 in. 16259 / 16254 / 16252...
Washing light blinking-will not work
Door switch? The unit might not be able to sense that the door is closed.
Mar 09, 2008 | Kenmore 24 in. 16259 / 16254 / 16252...
Kenmore double oven f4 fault code - door locked.
We had the F4 problem and called Sears repa. They sent someone out. The guy opened the panel above the bottom oven (we have a double oven) and hit a reset button - then charged us $75. This has worked on several occasions (my husband did it after that). But then that didn't work and Sear's told us it was the electronic panel which they replaced twice. Now it's (F4) happened again on the top oven only on a brand new electronic panel. So I guess it's the heat sensor this time.
Dec 31, 2007 | Ovens
Kenmore dishwasher model 63991 (10yrs old)
If the display works, but the machine doesn't fill, wash, or pump out, the control board is the only component that could cause all these symptoms.
Aug 26, 2007 | Kenmore 24 in. 16259 / 16254 / 16252...
Please help....It was just like a "Frankenstein" movie.
Normally that aarcing is due to food particles or grease trapped in the waveguide. It will arc over and over until it is removed. The other, worse possibility is that the stirrer or magnetron has failed. If it'sd still under warranty, I would call the nearest Sears store for service. If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://www3.sears.com (the 3 is correct)
May 07, 2007 | Kenmore 62702 Microwave Oven
Kenmore 24 in. 16259 / 16254 / 16252 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
