Hotpoint
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal
occurs due to belt slippage. I would check your belts (look for cracks.
Check the belt tension as well, most washers have an adjustment,
normally on the motor that allows you to increase the tension of the
belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
SOURCE: Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
SOURCE: LG Intellowasher 7kg 800rpm WD-8074FHB
It could be that the springs have become lazy (stretched) and not supporting the spinning weight as good as they once did or as happened to me one of the shock absorbers at the base of the unit has come adrift from its securing point. Replacement parts are easily available but you will need someone strong to fit them with all that new tension.
it sounds like an aeroplane taking off
