Question about Panasonic Palmcorder PV-DV203 Mini DV Digital Camcorder
Door Latch The cassette door won't "latch" closed. Is this something I can fix myself?
  • Shawn Dick Dec 08, 2006
    It's at the shop right now. The battery trick didn't work. Hopefully it's just an adjustment.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
The latch is reset by battery power - try charging the battery and reinstalling it. If that doesn't do it, it'll have to go to a repair shop.
Posted on Dec 06, 2006
What do I need to do in order to get the back door on the passenger side to close? A tech from AAA said I needed a spring for the door latch?
if it won`t close look at the door latch mechanism. there should be two u shaped claws that close around the door striker plate pin, sometimes these get closed before the door is closed causing the door not to close and stay closed. if they are closed(claws) pull the door handle to open the door and take something and push the claws out(open) then close the door.
Jul 08, 2014 | 2000 Plymouth Neon
Frigidaire microwave won't start when door is closed. It looks like the door does not latch properly. It worked 20 minutes ago and last night. How do you troubleshoot and/or fix the switches.
Hello Scott Noble - If I was in your position, I personally will recommend consulting a certified technician first for an accurate diagnosis. Depending on what part(s) is damaged from the door, the microwave could possibly have faulty switches, door switches, or latch which only a professional can repair.
Feb 23, 2013 | Frigidaire FMV157GM Microwave Oven
Back door won't close
take a philips screwdriver in between where the latch grabs the part of your car its is a circular area and release the latch at the same time pull down on the screwdriver and it will pull the latch back in the correct position to be able to agai n latch to the cars part of the latch to grab to
Dec 01, 2012 | 1994 Chevrolet Suburban
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
95 dodge caravan drivers door won't latch
often normal door latches will wear out causing the door latch to not activate the "full latch". The full latch ends up moving further up and into the latch. the solution is to replace the latch or have it rebuilt.
Aug 03, 2012 | 1995 Dodge Grand Caravan
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
When i close the door on my 95 chevy corsica it doesnt close. it just bounces back. please help im a girl and my parents dont know so use small simple words please.
I think what has happened is that the door latch (the one in the door) has somehow closed and won't let the door shut normally.
Here's how it works. The door latch consists of two major parts. One is the short, round metal tube thing that is attached to the car body about halfway up where the door shuts. Inside the door there is a latch in a slot that lines up with round metal tube thing when you shut the door. I think what has happened is the latch has closed, not allowing the door latch to slide over the metal tube thing and close completely. If you look at the latch in the door slot you'll (hopefully) see what I mean. Now how to fix it.
You'll need a medium to large screwdriver and maybe some help from a friend. First, lift the outside door handle like you are going to open the door. Hold it up. Then, with the screwdriver, push the latch in the door slot UPWARD until it clicks and latches.
It is difficult to put this in words but it usually is an easy fix. No damage done to your car (unless you REALLY slammed the door hard numerous times..).
Please re-post with any questions.
Mar 01, 2010 | 1995 Chevrolet Corsica
My back doors wont close all the the latch is in the down position ....how or what can i use to fix them the kids push in the latch ..its a 2006 bmw x3 sports edition
TAKE A SCREWDRIVER OR SOMETHING TO PUT IN THE GAP IN THE LATCH WHERE THE STIKER IN THE DOOR JAM IS WHEN IT IS CLOSED NORMALLY,& WHILE YOU HAVE THE SCREWDRIVER OR SOMETHING SIMILAR IN THE LATCH,PULL TOWARDS THE CAR WHILE YOU PULL THE HANDLE LIKE TO OPEN THE DOOR AS IF IT WAS CLOSED NORMAL,& IT SHOULD OPEN THE LATCH.
Dec 05, 2009 | 2006 BMW 3 Series
When i close the door i hear it close but i have to put something up against it to keep it washing if i take it away it stop washing
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Nov 19, 2009 | Maytag Dishwashers
DOOR WILL NOT CLOSE AND LATCH. PART MISSING FROM DOOR LATCH. CAN I FIX IT MYSELF?
I have this same problem. I've tried to fix it many times but can't figure it out. That's why I'm on here.
Nov 16, 2009 | 1995 Mercury Cougar
Panasonic Palmcorder PV-DV203 Mini DV Digital Camcorder Logo
95 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
