Question about Gateway (4000782) Motherboard
Gateway series 300 with 4000783 moBo, no visual
Removed hard drive to match up w/new one- didn't get new one yet. Reinstalled Hard drive, now monitor says "no signal,check cable". Gateway says video "card"is built in to MoBo and that is where problem is. Can I put this hard drive in my Dell Dimension 3000 to extract all my info and just scrap the gateway without corrupting files or running into compatiblity issues?
  • matt scheeler Nov 18, 2008
    Can anybody help me on this siuation?
  • 172 Answers
Gateway are most likely wrong. These Gateway cp's usually have a motherboard failure which stops the cpu socket working, replacing the motherboard is a far cheaper option than buying a new pc, restore windows using my rstore disk which uses your registered version of XP. You could put the hdd in a dell computer, set the jumper omn the back to secondary master or slave of either the primary master ( C:\) or the secondary master.Then copy the files you wnt to an external source or the dell pc.
Posted on Dec 01, 2008
I have a old gateway pc and I would like to install a Hard Drive from a Dell pc into it. Can it be done?
Swapping the hard drive from the Dell into the Gateway will not work because the Dell hard drive has been installed with Dell specific drivers and configurations.
When you install the Dell hard drive into the Gateway you need to wipe the hard drive and install a fresh copy Windows XP onto this hard drive and the Gateway device drivers etc.
Oct 29, 2012 | Computers & Internet
I have a Gateway Laptop M-series SA1 Video Drivers
This software Driver Update Software for XP Vista 7 8 contains your video drivers (and every other driver). wish you best of luck
Jul 21, 2012 | Computers & Internet
I need to re-connect the internal DVD drive in my daughters Gateway MX6428 laptop. She apparently dropped it and it no longer registers it's connected. We've taken all the panels off of the bottom. No...
How to Remove Replace and Install Your Gateway MX series MX6428 Laptop Hard Drive
1. On the bottom of your Gateway MX6428 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Gateway MX6428 hard drive caddy, or simply remove the door.
4. Once the Gateway MX6428 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Gateway MX6428 hard drive.
Nov 12, 2017 | Gateway MX6428 Notebook
Laptop turns on but only Gateway screen with Boot Menu:<F10> BIOS Settings:<F2> comes up
Your machine isn't able to find the windows software on the hard drive, and most likely you need to get the hard drive checked. If you press F10, does it show you the hard drive?
If so, you probably need to get windows reinstalled. If not, it's likely time to get a new hard drive.
It's an easily accessible part to get to, so the repair shouldn't cost alot, and hard drives retail between $30 and $100 depending on size and speed.
You will need to install windows on it afterwards.
Aug 18, 2010 | Gateway MX6421 Notebook
Fan works but no beeps, no video signal. Tried some suggestions.
sometimes pulling the power cord out of the pc and then replugging it will let it reboot. for some reason these machines die, and they will not reboot until you take all the power off the motherboard for about 10 seconds.
Jun 25, 2009 | Gateway GT4016 Desktop PC
Ccomponants will not power up
Your hard drive is junk. Replace the hard drive.
May 23, 2009 | Computers & Internet
My Pc wont boot no signal in my monitor Help!
May be your in second HDD, you didn't set the jumper up. There are some more settings you will have to configure in the BIOS menu. in the BIOS, you should set the primary HDD as the master and the second(newer HDD) as the secondary. Then it should boot without any problem but if the problem persists I don't know what to do next.
Mar 08, 2009 | Abit IP35P Motherboard
No Video
Try another power supply. I believe you would have this problem if your 4-pin connector from the power supply is not connected to the board. Of cause, you might have a defective board.
May 22, 2008 | ASUS A8N-E Motherboard
Gateway (4000782) Motherboard Logo
191 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
