Question about HP LaserJet 1010 Printer
Paper gets folded at the edges
My printer is HP LaserJet 1010.The printed paper folds at the sides when it is printed.On checking it was found out the roller is defected.What is the solution?Please help...
  • yolanda67 Feb 18, 2009
    Paper folds on one side. Can something be stuck inside the roller that causes the paper to fold? Can I open the printer myself?
  • Asish Sharma
    Asish Sharma May 11, 2010
    Which roller is faulty...please give details....description...location
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
Clean damaged roller with the special liquid for recover rollers )) That's all))
Posted on Nov 17, 2008
HP 4250 SKEWING PAPER
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
HP color laserjet 4600 folds paper
Clean the inside and check for any gunk built up try unplugging it for atleast 2 hours if neither helps then probably will need to be changed also try doing a calibration on it before buying item
Apr 26, 2017 | HP LaserJet 4600dn Color Printer
PRINT OUT WITH FOLDED PAPER FROM HP 1010 LASERJET
This is caused by a worn fixing film assembly ( fuser ), situated at the rear of the printer. It needs to be replaced but dismantling the printer is not that easy
Apr 10, 2010 | HP LaserJet 1020 Printer
Paper is jamming when I print something
Were you able to remove all of the original jammed business cards? where the leading edge of the "Fanfold" prints occurs, you will probably find something blocking the paper path. HP printers usually have a limit on the paper weight that the printer can handle when doing duplex (2 sided) printing. Check this against the weight of the cards you are printing.
Apr 18, 2009 | HP Color LaserJet 2600n Printer
Hp laserjet 1320tn folds the upper right-hand corner of the page
Check carefully for any small scraps of paper caught in the paper path. Do a 1/2 way test, do a print job, listen for the paper to get just under the toner then quickly open the front of the printer (may take a few tries) see if the paper is folded there or if it's happening later that way. If it is folded before entering the fuser, you probably have a small piece of paper in the paper chute somewhere. If it's not and folds later, the fuser is probably worn badly.
Feb 09, 2009 | HP Laser Jet 1320 Printer
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
Misalignment messing up paper edge and printing
I would says check the fuser assembly for the folding the paper problem and the text tilting is a scanner/laser issue.
carefully check the paper path for anything blocking the way.
print a test page and open the lid when the paper is inside to stop it, inspect the paper to see if it's folded and also see the image on the paper to see if it's ok before reaching the fuser
hope this helps
Jan 04, 2008 | HP LaserJet 4p Printer
Quality of printing
For the black line check the toner cartridge roller (usually covered by a movable flap) to see if there is a black line on it. If not, then check the transfer belt (looks similar to a conveyor belt) for a line (probably not black in color, possibly white or grayish). If either of these parts have a line your best option is to replace that part. You could try cleaning VERY gently with a dry lint-free cloth but this may only clear up a little of the issue.
As for the fold, try running a paper path test, usually found under test, information, or diagnostic menu option on the printer itself. Try to find anything in the paper path that may catch the paper and cause it to fold.
Hope this helps!
Nov 27, 2007 | HP Color LaserJet 2600n Printer
HP LaserJet 1010 Printer Logo
135 people viewed this question
Seeker5211
Seeker5211
