Question about Krups Small Appliances Espresso Machine
I Have a Krups Espresseria automatic coffee machine & my problem is the water indicator in the water tank does not rise when the water tank is full so the machines keeps telling me to take the water tank out ,fill the water tank & put it back in.I Have try to shrink it with hot water & that only works for a couple of days,please help me.
  • Krups Master
  • 1,711 Answers
Inside the water tank there is a magnetic float which is causing the problem. This float is moving always on the top of the water tank as you fill it with water and in reverse as the water level goes down then the float is moving down to bottom also. So as the magnetic float is moving up and down is giving the signal for the water level if it is full or empty.
So possibly now the float is stuck in the bottom and even if you have refill the tank this is still on the bottom of the tank. This can happen from many reasons. First could be that the plastic column that the float is moving is full of scale and it can not move up and down freely any more so you can clean it from scale by decaling it and even clean it with a wire brush.
A second possibility could be that float have a tiny hole and some water enter in the float and this make it to stay on the bottom of the tank. You can visually inspect it and if possible you can dry out the water and weld with a super glue the hole if possible, if it can not be fixed then you need a new float.
If you wand to fix it temporary until you find a new float you can a plastic clip or similar to secure it always on the top however you when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid any other problems with the machine.
Good luck
Posted on Jun 16, 2010
Krups Espresseria Automatic Premium machine repeatedly displays the following message "Filling of machine necessary".
You may find that whatever detects the water level is faulty. Normally there will be a magnet that floats in the side/back of the tank. If it's sitting on the bottom of the tank then try and shove something plastic between it and the bottom of the tank to lift it up. If that fixes it then you have a choice to leave it like that or buy a new tank.
Feb 08, 2017 | Krups Coffee Makers & Espresso Machines
ERROR CODE E09 TO EA82
There is a problem with the heating of the thermoblock, it will require dismantling to check.
Feb 24, 2015 | Krups EA8250001 Espresseria Full Automatic...
How to stopp the leaking under the watertank?
Normally solved by replacing the tank seal where the tank plugs in.
Aug 30, 2014 | Krups EA8250001 Espresseria Full Automatic...
Coffee scraper arm sticking
You will need to remove the brewing unit from the base and tip it upside down to inspect/free up the mechanism. While you have it that far replace the seal (barista seal) at the bottom of the brewing chamber that seals the rod on the ejector mechanism. Also inspect the back of that sweeping arm where it runs in a track at the back of the tamping piston ram. A new tamping piston with seals and tank seal would not go astray, all the parts are relatively cheap NZ$40 easily gets the lot.
May 19, 2014 | Bialetti Mokona Espresso Machine
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
Krups Espresseria Automic XP7200 coffee machine
As this is an automatic espresso machine, I suspect that the cake container is where the "used" pucks of ground coffee drop into after your espresso is extracted. The container may not be fully seated in position. See if there is a door on the machine that the container may be hiding behind.
Good Luck.
-Steve
Sep 27, 2008 | Krups XP7230 Compact Super Automatic...
Krups xp7420 espresseria automatic
am o proare 01 la un espesor krups 7220/7240
May 11, 2008 | Krups Coffee Makers & Espresso Machines
Krups Small Appliances Espresso Machine Logo
458 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
