Question about Adcom GFA-5503 3-Channel Amplifier
Lots of hum from both speakers
I'm getting a lot of hum and buzzing on both speakers making quiet passages in music less than quiet. I have checked any possible power cord interference without any effect. The hum begins when the Adcom is turned on and only diminished after the pre-amp is started. Still, it is too loud to be exceptable. Any suggestions?
Well folks I solved my problem and the amp has never sounded better. It had always hummed and now it close to stone quiet. The secret was it really never a problem with the amp. The problem was the result of either the pre-amp, interconnect cables, or the combinations of them. The solution came when I added a "drain wire" or ground to the cable I was using. There must have been a ground loop or some in-balance that required a wire to be connected to the earth (-) side at the source on the interconnect and then left unconnected at the other or receiving end of the interconnect. Anyway, no more hum, and the solution took some spare wire and solder.
Posted on Nov 23, 2008
NHT SubOne makes hum when the standby mode is activating and when playing music there are pops when the volume gets loud.
Hums are generally caused by electrolytic capacitors that have gone. You should replace any large ones in the power supply section of the unit.
May 28, 2017 | The Audio Players & Recorders
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
I get a loud intermitant buzz from one of my JBL eon 15-G2 speaker, no music signal just buzz. What is the problem do you think...? EQ circuit problem, speaker cones seem to be intact.
If you turn the unit on with no input and get a loud buzz, and when you put signal to it and you cannot hear the music but the buzz (Probably more like a hum). Then most likely the amp is blown.
Dec 13, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
I have this constant buzz from the speakers...I notice it less when music is playing but it is still there. what can I do?
Make sure that there are no magnetic interference to the speakers. Its should be because the speakers are kept near some electronic or magnetic device...
Just try moving the speakers and notice if there is a change in the buzzing, if yes... then its definitely some interference on them.
Get back to me if that does not resolve it.
Nov 16, 2010 | Bose Companion 2 Computer Speakers
BUZZING NOISE LIKE 60 CYCLE HUM, CHECKED CORDS AND MIXER AND POWE
When the speaker is connected only at the power line does it makes this noise?
  • If it does it's an internal amplifier's ploblem and you have to check out some fittings (electrolytic capacitorsat the power supply, power supply transformer, voltage stabilizers e.t.c.)
  • If the speaker is quiet you have to check your external wiring because there is a loop ground. That means that one "ground level" line is connected at the ground by two or more cables (e.g. the audio ground and the grond from the mains power source) In this case disconnect the second (and the 3rd e.t.c.) grounding point.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 10, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
The noise is a hum or buzz. We've narrowed it
By chance have you tried making sure the laptop is not too close to the speakers? Sometime you will get feedback when the source is to close to high powered speakers. Also, check your jack cord and make sure no splits/cuts are visiable and the plugs are fully inserted.
Good Luck and keep making great music. Aloha.
C2Solutions
Sep 02, 2009 | Dell Inspiron 6000 Notebook
Static humming from speakers
I've had the same problem and I think I've solved the problem. I noticed that they were fine when I first turned them on. After a awhile the blue light would flicker and static would start. I figured there might be some connection so I unplugged my speakers, took off the thin rubber from bottom and removed the 3 small screws. I carefully pulled the circuit board down, spotted the led light and snipped it off. I put everything back together, double stick taped the rubber piece back on, plugged it back in and have been listening static free for hours. Yippee, no more room full of screaming babies (that's what static sounds like to me)! By the way, I'm no expert. I just have a very strong aversion to static.
Good luck,
Beth
Mar 14, 2009 | Insignia 2.1 Speaker System (3-Piece)
Mackie srm-450 constant annoying hum (buzzing) even with no input plugged in
Mix, try this...Get everything in your audio system together.get a coupla power strips. Power up both speakers on that strip with no inputs, just the speakers. gotta hum(60hz)? ground-lift the strip and see if it stops. add one peice of the puzzle at a time until you find your buzz generator, if you're a mobile DJ, doing gigs in 'God Knows Where' you would be well advised to buy a "Power Conditioner" that will level out spikes and dips in the voltage servicing your gear.
Sep 06, 2008 | Mackie SRM-450 System
Adcom GFA-5503 3-Channel Amplifier Logo
362 people viewed this question
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
Greg Cann
Greg Cann
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
