Blocked disc tray - Televison & Video
  • arboc Nov 18, 2008
    Kenwood DV-605, DVD/CD player, seems like the disk tray is blocked.
Disc tray keeps becoming blocked . have to unplug recorder several times to unblock
Posted on Dec 31, 2008
How do I unjam a disc stuck in the 5xCD tray of a Sony DAV-C770 compact AV system?
If you experience difficulty with the disc tray opening or closing, follow these steps to try to resolve the issue.
  1. Turn off the power to the disc player or the stereo system, if the disc player does not have a separate POWER button.
  2. Unplug the power cord from the AC outlet.
  3. Verify there is nothing is blocking the tray from opening or closing.
  4. Let the disc player or the stereo system remain without power for approximately one minute.
  5. Plug the power cord back into the AC outlet.
  6. Turn on the power to the disc player or stereo system.
  7. Attempt to open or close the disc drawer or tray.
If the issue is still unresolved, service may be required.
this is direct from sony hope it helps
Dec 31, 2014 | Sony DAV-C770 System
Dvr drive tray will not open
In the cover of the tray, look for a small hole the size of a pencil lead. Get a paper clip, straighten it out and push it into the hole. That should release the tray so you can get the disc out.
Jan 20, 2018 | Philips Dvdr615 Dvd Recorder
MY id58 GATEWAY DVD PLAYER, i cant insert a disc because blocked by the mechanism eventhough there is no disc inside.
There is a small hole on the front of the drive. Use a paperclip or a safety pin in the hole to push open the disc try enough to pull it open the rest of the way with your hand. Insert the disc, press the button on the drive to close the bay. If the tray doesn't close gently push the tray back in. If no lights blink on the front of the drive, the drive may be unplugged or has gone bad.
Jul 06, 2011 | Computers & Internet
It is locked and we do not know how to get it unlocked. It states we need a code and we do not have it.
Do you mean it is disc locked or tray locked? If it is tray locked, it may require workshop attention, which could be expensive (depending on the nature of the problem). If it is DISC LOCK, try this:
Up to 20 discs can be locked.
[ Lock ] - To block the playback of the current disc. Subsequent access to a locked disc requires a six-digit password.
The default password is 136900.
[ Unlock ] - All discs can be played.
(You enter the six digit code as above then press OK on remote) (resourced from elsewhere)
Apr 18, 2011 | Philips DVP3982 DVD Player
Discs not playing
Don't know this issue with this particular player, but have had other Technics (Matsushita, Panasonic...) CD players doing something similar to this. In most cases, those were carousel players instead of single disc players like yours. These units had optical sensors that determined the presence of CDs in each tray slot by determining whether light was blocked from its LED to its sensor when a disc was present... no light at sensor meant that there was a CD in the slot. The sensors interpreted a shadow as an indication of a disc in the tray. I've had these sensors fail and not be able to determine that a disc was blocking its light signal... the players didn't "see" discs so they wouldn't play them. Solutions varied, but cheapest, easiest solution was often to open the player and blind the sensor completely with a piece of black electrical tape. Most of these sensors I have encountered got too sensitive, so that any light at all inside the player was seen as an empty slot. Blinding the sensors "fixed" most of these players, but disabled the ability to really tell that any given tray slot was empty.
Or, since it is an old player, there is also the possibility that it has simply run its course and the laser assembly has failed.
Good Luck.
Jul 24, 2010 | Technics SL-PG480A CD Player
Tray will not budge it is all the way closed?????
the button that can open the tray isnt powering correctly. but it could also be that if you have a disc in there that it would block it from opening if you have dropped it.
Dec 11, 2009 | Microsoft Xbox 360 Console
The tray on my Phillips DVDR 3380 won't open. It says blocked or no disc. I have pressed open /close many times but to no avail.I have turned the power off, makes no difference. I have press stop when it...
I have the same problem. What I do is push my hand down firmly on top of the DVD Recorder above the tray and while doing this press the open button. If this doesn't work get a screwdriver and poke it into the sides of the tray and pull it away. I find that the first method works best! XD
Hope This Helps!
Jul 04, 2009 | Philips DVDR3380/05 DVD Recorder
Games wont play
Check if theres anything blocking the disc drive.If that doesn't work each game has a warranty.
Jun 26, 2009 | Microsoft Xbox 360 Console
Philips DVR model HDRW720/17 Display screen shows "Blocked"
Do you have a disc locked up inside? I found that there IS a manual release for the disc tray UNDERNEATH the unit. It is a sort of toggle lever that you have to slide to the other side and that releases the disc. The Manual does not even mention this manual release lever!
Also, it may be hidden or covered by a paper like cover.
GL
Oct 30, 2008 | Philips HDRW720 DVD Recorder
Playstation
it sounds like the disk isnt locating when it slides onto the laser tray if you are ok taking it apart check nothing is blocking the laser tray if their is nothing blocking it check that the laser has retuned back to the middle of the tray if it hasnt then gently push it back and then put it back together. if this dont work you might need to buy new laser witch you can get off ebay they are easy to fit the wires only go into a snap conector try this this should solve your problem
Oct 28, 2007 | Sony PlayStation 2 (PS2) Console
Televison & Video Logo
773 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
