Jenn-Air JCD2295HES Side by Side Refrigerator Logo
Terrt Sillito Posted on Dec 01, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Icemaker is not freezing ice, freezer not freezing food,
My icemaker is not making ice, the freezer isn't freezing. Puddle of h2o at bottom of fridge. (jenn-air)
  • 5 more comments
  • Anonymous May 25, 2008
    My freezer no longer freezes ice. Is it broke and time to get a new one?
  • Anonymous Mar 13, 2014
    freezer ices up. Icemaker doesnt work Best buy will not help
  • Anonymous Mar 24, 2014
    the ice forms into big frozen blocks in my icemaker
    ioce freezes solid
  • Anonymous Mar 29, 2014
    not freezing food
    food is not freezing
  • Anonymous Mar 30, 2014
    ICE IN THE FRIDGE BOTTOM
Anonymous
Level 2:
  • Expert 237 Answers
  • Posted on Dec 04, 2006
Anonymous
Expert
Level 2:
Answers
237
Questions
Helped
455367
Points
660
The ice maker won't work if the freezer is warmer than 17 degrees so that's not an issue till you get the freezer cold again. I would guess that your unit is stuck in the defrost cycle. This could be the defrost timer failing. See if you can find the defrost timer in your unit and advance it by hand if possible. http://www.partselect.com/PartSearchResults.aspx?modelnum=jcd2295hes&mfgmodelnum=&fkmfgid=1&hint=defrost
Water in the bottom of freezer.
It sounds like the drian line may be pluged with frozen ice or debris like food particles and plastic paper etc. when the water is not able to drain it will usually freeze up and effect the cold level in both freezer and fridge. sometimes a bad evaprorator fan will not circulate air can can cause drian plug issues. do u hear the fan operating? if you have a soft long wire or tubing you can unplug the drain line by pushing tube or wire into the line and force food down to exit, see pics Im sending, are you having any issues with freezing in freezer?
1helpful
My Ic13b icemaker but when ice tray is full it still adds water to icemaker causing it to overflow and freeze on bottom of freezer
either your ice maker is calling for too much water or the water valve isn't shutting off when the ice maker tells it too. The best thing to do is to change both the ice maker and the valve because if one is defective more than likely thee other will fail shortly
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Ice freezing up on bottom of freezer and water MFI2269VEM3
Sounds like your drain in the freezer is clogged. Try a flexible item like a guitar string to clear it.
BUT also make sure that the fan is working and blowing the humidity from the freezer to the fresh food section.
My ice cube maker isn't making cubes,but I still get water
hello,
In a case like that usually the problem is going to be a cooling issue, is the fresh food and freezer section both cold? it obviously takes water and freezing tempatures to make ice.
2 things to check are
1) the condenser coil under the grill below door or on back depending on model is clogged with dust and needs to be cleaned
2) the fan in the freezer isn't running circulating air into ff section and directly onto icemaker
Good luck, i hope this helps
Gene
The ice maker was making ice then some of the ice turned yellow and now the ice maker has stopped making ice. The freezer is still freezing the food in there.
The icemaker concists of a gearbox that has oil inside it.When the gearbox wears, it starts to leak at the shaft. Suggest you replace the icemaker.
3helpful
2answers
I have a maytag bottom freezer refrigerator model#mbf1956keq
apparently its the way the maytag defrosts. I have had this issue since I bought it. FIrst of all, you dont have to go through the whole defrosting process with water on the floor and removing your freezer contents. Simply take a butter knife and from the front corner, slide it under the edge of the ice and the whole sheet can be slid out intact right under the freezer door. I think it had alot to dowith having the humidity switch on, because when it isn't like in the summer when the AC is running, the amount of ice is not that bad.
3helpful
2answers
Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Water from the icemaker shoots down the back of the freezer
are you sure the water comming from the icemaker or the defrost drain line clogged
Top Jenn-Air Refrigerators Experts
john h
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
