Question about Kenmore 63252 Microwave Oven
Low voltage When our microwave Kenmore model 721.63252301, serial No.603TAO1746, is in operation, cause a low voltage in the house net. When is not in use the operation voltage in the net is normal. What is happening with this device. Thanks
Solution: I assumed the device was in good condition, because heat without problem, then I isolate the failure in between the main breaker and the outlet.
The problem was in the line. (110 volts) not properly grounded and maybe with bad size of diameter wire.
I made a independent power supply only for the microwave including his own breaker.- The problem is over. Thanks.
Posted on Nov 17, 2008
Can low voltage cause magnatrons to fail?
That would depend on how low the voltage gets. Because the lower the voltage gets, the more current the device draws at that voltage to operate. Higher currents can, in some cases shorten the life of electronic components if those components aren't designed to operate under those conditions. I have a microwave oven that operates on a 120V AC circuit. This circuit normally carries about 117VAC, with the microwave under full power, the line voltage drops to as low as 104VAC. This is just due to the load the magnetron puts on the circuit. If you lowered the voltage by about 5 volts in my case, the current draw would be enough to trip the 15A circuit breaker that protects the circuit. If I were operating the oven on a 20A breaker with 12 gauge wire instead of the 14 gauge, 15A circuit I'm using, the voltage drop would probably be a lot less.
Nov 01, 2016 | Microwave Ovens
Kenmore Elite microwave model 85513 doesn't heat like it use to only 1/3 power what has to be replaced
An intermittent or failing magnetron could cause the problem. Although extremely rare, an intermittent high voltage rectifier can also cause this.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Oct 16, 2016 | Kenmore Microwave Ovens
How do I fix Microwave?
Replace the Magnetron and diode pack. DO NOT DO THIS UNLESS QUALIFIED Dangerous voltages are present!
Jul 14, 2014 | Kenmore Microwave Ovens
Kenmore elite microwave not heating
This a common issue and caused by one of three things, magnetron, "heats food" cracked high voltage diode, and a shorted high voltage capacitor.
Mar 23, 2012 | Kenmore Microwave Ovens
Kenmore microwave model numbr 72180039700 does not heat anything
The cause will be one of three things, the magnetron "common problem" or the high voltage capacitor and diode. If the magnetron turns out to be the problem, it will be cheaper to replace the microwave oven.
Mar 10, 2011 | Kenmore Microwave Ovens
Danby Designer 1.1 cu.ft. Microwave oven model DMW1158W I came home from work...went to heat up some lunch and the microwave didn't work. I thought maybe the power was off...no...power was on. I...
Weird that it worked when you left then not. Have you had the lights inside of your house dimming off and on?? It could mean a bad neutral connection to your house from the power pole. That can cause the low voltage transformer on the timer board to burn out. So the fuse in the unit will not even blow but still kill the Low Voltage transformer. If sounds possible call your power company to do a "load test" on the incoming power lines to your house.. They don't typically even charge to do that. They take out your meter and put a tester in that spot that tests the supply to your house.
Oct 17, 2017 | Danby Microwave Ovens
Microwave hood # 721.80833500
One of 2 things are happening..One of the thermo protectors has a bad connection (Kenmore is good for these) or the Magnetron has a leak inside the control cavity causing a temporary short in the control.
Dec 30, 2008 | Kenmore 80809 Microwave Oven
Microwave heats but slowly.
This is the second time I have requested assitance on this site with no response. The beginning of this thread dates back two months. Why would I ever want to pay for support when it is so poor at this level?
Jan 06, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore over the range Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Dec 05, 2007 | Kenmore 62622 Microwave Oven
Kenmore 63252 Microwave Oven Logo
80 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
