Question about Sony KP-51HW40 51" Rear Projection Television
Sony kp53hs30 My TV gor water in the back of it and it distorted the picture. I had a repairman look at it and he told me to replace the D board so I did, But the picture is still curved and 3D looking. It is not as bad as it was before, but it is still messed up. Is this something that can be fixed by having it focused or is it something else? It doesnt look like there are any more parts with water damage. It was just a little bit of water. Thanks
    Sergeant:
    Champion:
  • 375 Answers
Ty activating magic focus if your set has that feature,if not you require work on the convergence alignment
Posted on Oct 24, 2007
How do I know which part to replace in my LCD TV...is it the backlight or t-con or main board?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 23, 2015 | LG Televison & Video
When I turn on the set, the right half of the screen is distorted. It flickers, different colors move from center to far right of screen, double images that appear as negitives and sometimes that half of...
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
Jan 29, 2011 | Samsung LN46A550 LCD TV
The image on the TV jitters from side to side rapidly, distorting the entire image on every input. I was told perhaps this is a voltage ripple problem; I replaced a bad capacitor already and it helped...
Replace all capacitors in Hyper Module mounted on main board of tv to solve this issue. These are maybe 10 capacitors, replace them all, this will solve your tv picture problem.
Thanks.
Dec 27, 2010 | Toshiba 50H82 50" Rear Projection...
WHITE DISTORTED SCREEN
U Main Tuner signal board is dead.Replaced the Main Tuner board will solved this problems.Picture was white distorts,he should of replaced the Main Tuner board.The T-con control board only replaced when u have power to tv,but no video.When have any kind of video on the tv all it way cause by Main Tuner signal board.
Mar 17, 2010 | Televison & Video
Tv picture is distorted like an hourglass
rejihfghierbguiyorebgierosbgeruisssssssssssssssssssssssss
Aug 19, 2009 | Televison & Video
Shrinking Picture
problem is bad soldier on the vertical IC , this part needs to be resoldier to solve your problem, its a simple job for any tv repairman.
Jan 10, 2009 | Toshiba 36A40 36" TV
Picture is extremely distorted
generally Samsung makes great units. but its definitely not worth fixing. recycle it and indvest in a new unit.
mj
Dec 22, 2008 | Samsung DynaFlat TX-P2775H 27" TV
Samsung HL-S5087W DLP picture is distorted
If the picture is distorted it probably needs reapir. I recommend doing a little research to find a reputable reapir shop. You can ask where you bought it or where they sell TV's. If you get two answers the same it might be worth talking to them for pricing.
Nov 21, 2008 | Samsung DLP HL-P5663W 56" TV
Distorted Color and geometry of Picture
Sounds like a convergence IC problem, you will need to replace them'
Heres a quide
see the before and after pictures to verify your problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 15, 2008 | Televison & Video
Distorted picture on RCA LCD TV
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
Sony KP-51HW40 51" Rear Projection Television Logo
95 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
