Question about RCA Scenium HD65W20 65" Rear Projection Television
Replace the green projection gun
I am attempting to fix my fathers RCA Projection TV and ordered a kine-green projection gun part #256714. I need to know how to put the coolant into the gun and how much to put in. Also should I check the red and blue guns for the correct amount of coolant??? How would this be done? Thank you for your help...
This is a very difficult repair to try and make. You not only have to replace the tube, but when the tube is replaced, you will have to perform convergence adjustments, which are very difficult. The green tube is the worst to try and replace because the red and blue tubes are converged onto the green which means now you will have no reference point to start from. It's not just a matter of dropping the new tube in and turning the tv on, also if you but the tube as an RCA original, it will come already filled with coolant.
Posted on Jul 28, 2007
I have almost the same problem, but it was with the blue CRT tube. The coolant leaked onto the underlying PCB and caused short-circuits and sparking or arking. I purchased an exact replacement PCB for the CRT, but I suspected most of its coolant had gone, so I need to re-fill the coolant for the blue CRT to stay cool.
Posted on Jun 14, 2007
I have an RCA Scenium HD DLP 50" TV Rear
What is the Model Number that is printed on back of TV?
You say TV is DLP ,but you are posting Model# HD52W59 that is for Projection that has 3 Tubes Red/Green/Blue Tubes.
If TV is DLP then problem will be the Color Wheel
If it is Projection then it has a coil on the deflection board that either needs to be replaced or
resolder ciol and take a Glue gun and glue over the top of coil. Coil LL037 on the right handside of the FBT flyback transfomer.
Jan 13, 2011 | RCA HD52W59 HDTV Projection Television
No Red color at all. The convergence feature does not work either. Lots of green and blue RCA Model D52W59
Red color gun has failed, which will make the picture over saturated with the other two colors(blue,green) the bad news is the three color guns need to be replace in a set(all at the same time) because if you only replace the red it will over saturate the older blue, green guns then your picture will be mostly red.Unfortunently in most cases it's not worth the investment, better off to purchase a new tv. Good luck !
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
RCA projection tv is blue and fuzzy
may be convegence try turning down the blue screen and see that that does see if the picture clears...
Feb 04, 2009 | RCA Televison & Video
Thin vertical lines
Those lines are called retrace lines. They are there all the time on projection TVs but you should be able to see them. When you do see them, that's an indication that the kine screen settings are too high or the supply voltage to the kine driver circuit is low or missing. There is a small, black control unit located behind the speaker grill assy in the front of the TV that has 2 sets of 3 controls. A red, blue, and green focus and screen controls. See if you can make the lines dissappear by turning the screen controls counterclockwise. If you can't you'll need to have service come out to troubleshoot it.
michtech
Feb 02, 2009 | RCA D52W19 52" Rear Projection Television
Green color board replacement
if its the board that attaches to the center gun its called green crt pcb
Apr 13, 2008 | RCA P46921 46" Rear Projection Television
Rca guide plus gold 52 in projection tv
sounds like the blue CRT is contaminated open the back turn on the tv look into the blue gun if it looks snotty the coolent needs to be replaced
Oct 31, 2007 | RCA P52926 52" Rear Projection Television
RCA Scenium HD65W20 65" Rear Projection Television Logo
232 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
