How do i remove the child lock from my tv as i dont have the code
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code
SOURCE: help me to remove the Child Lock
unfortunately Hitachi created these
tv's so that you could only remove the child lock by accessing the menu with the original remote only.
Sorry!
SAM
SOURCE: Remove Child Lock on panasonic TV CT32G4
contact panasonic there should be a 1-800 number on the back of your set. OR look up www.panasonic.com this information can be given to you over the phone.
SOURCE: tv works but dont have code for tv its like a
default code is 0000.
If you forget your password you can reset it.
Simultaneously press the VOL+ on the remote and
the CH+ button on the front of the TV. The display
the CH+ button on the front of the TV. The display to reset, simultaneously press the vol+ button on the REMOTE, while pressing the chan+ button on the front of the TV. Reset Pass Display will appear. Thanks if this helps, please give a good rating
SOURCE: I need to remove child lock (without remote)
hi did you get to solve your problem becuase i have the same problem
Instructions
Locate
it.
Try
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
