Question about Mitsubishi WS-65909 65" Rear Projection Television
Turn the speakers to ON
The function within the tv/audio menu won't allow me to turn the internal tv speakers to: ON. it isn't even highlighted. it is somehow disabled. is there a way to enable this?
  • melissabryso Dec 28, 2008
    Did you ever find the answer to this?
  • jason May 11, 2010
    have you been using the hdmi input ?
  • 905 Answers
If it shows the speaker setup in the menu , then try to reset the speaker settings in the menu
the reason i ask about the hdmi is because this can mess up the internal sound and video
so try to reset the speakers setting in the menu , but if you have an external audio output connection to the tv , like to a reciever , then that could have messed up the audio inside the tv , so also unhook any source to the tv that has the audio connectors hooked up and see if you can then turn on the internal speakers
electech
Posted on Nov 17, 2008
No I am not using a hdmi input. This problem exists within the unit itself. I am unable to manually turn on the Televisions internal speakers. they are currently set to off and are not highlighted within the menu to be able to turn them back on. I hope this helps. thank you!
I have a sharp aquos tv, model LC-42D62U, and had a sound bar attached that worked great. When I remove the soundbar I can’t get the TV sound to turn on. I have trouble shot a lot of things. The problem...
I do not have sharp manuals to reference - in general the TV sound - Variable vs Fixed just allows the set to control the volume output (variable) or Fixed will produce one level of output and your device (soundbar) volume control would adjust up or down from there. There is usually another location in the menu that allows you to turn off the TV speakers so they do not operate at the same time as your soundbar or other device. It should be simply Speaker ON / OFF. If you can locate this - you should be able to select it. If it is all greyed out - that means the TV believes based on the connections / setting / input selection - those cannot be changed. (you may try connecting the device and see if the greyed out menu items turn back white or are selectable. Sorry I don't have a specific answer - hope this helps
Dec 21, 2017 | Sharp Televison & Video
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
Sound output to a sound bar
Most TVs have a menu setting that says internal or external speakers.Here are the instructions for yours.
Turning off the built-in speakers Use this feature to turn the TV speakers off when you connect an
audio system (see "Connecting an audio system" on page 11).
To turn off the built-in speakers:
1. Press MENU, then press x or • until AUDIO menu appears.
2. Press y or z to highlight SPEAKERS.
3. Press x or • to highlight OFF.
Feb 16, 2014 | Toshiba 36HF71 36" TV
No audio to internal speakers,audio out to amp is good.
THIS AUDIO PROBLEM PERTAINS A FEW DIFFERENT NAME BRANDS AND TO MOST VIZIO Tv MODELS
MADE IN THE LAST 2-3 YEARS MAYBE EVEN 4+ I'M NOT SURE
WHEN IT STARTED.
I do believe your model is equipped with the SRS features which IS a formatted audio enhancement . Anyway go into the advanced audio settings in Tv's menu and TURN OFF the SRS tru volume leveling & the SRS tru surround feature. Additionally in the Tv's menu also has an option to turn off the internal speakers. And another common pitfall that I see happening to people. Is check the PCM and or LPCM option in both your Tv & your cable/satellite box's audio menu setup/settings. LPCM is Limited Digital Audio and PCM is Variable Digital Audio (VOLUME AMPLIFICATION) but
because it is a digital signal the two formats conflict, and the audio
will in and out.
WHEN IT STARTED.
P.S. YOUR WELCOME I SAY THAT CAUSE QUITE OFTEN IT IS
THE AUDIO PROBLEM VIZIO CUSTOMERS ARE HAVING!!!
Jason Draimen AKA "AVALANCHE" !!!
Apr 01, 2013 | Vizio VF550M 55 in. LCD HDTV
I have a L46FHD37 lcd tv how can i reset it
The Sound menu lets you adjust audio output. To access the Sound menu, press MENU on the remote, and then select Sound from the Main Menu. The following audio items can be adjusted:
Equalizer The five-band graphic equalizer lets you adjust the audio frequency settings. You can select one of the five-band Equalizer Presets or create your own personal preset.
Sound Preset Allows you to choose a specific Sound Preset. Press the right arrow to cycle through the options: Standard, Movie, Voice, Music and Personal.
Frequency Range Displays the different graphic equalizer bands set for each Sound Preset option. Choose a band and make adjustments. When you make adjustments, the Sound Preset option automatically changes to Personal. Press the left or right arrow button to select the frequency (100Hz, 300Hz, 1KHz, 3KHz, 10KHz) you want to adjust. Then use the up or down arrow button to adjust the level. When you're done adjusting the levels, press the MENU button to exit.
To view the frequency range of another Sound Preset option, press the right or left arrow until no band is selected and Frequency Range is highlighted. Then press the up arrow to highlight Sound Preset.
Sound Type Controls the way the sound comes through your speakers. The options available vary according to the input selected.
Mono (available for regular TV viewing only) Plays the sound in mono only. Use this setting when receiving broadcasts with weak stereo signals.
Stereo Splits the incoming stereo audio signal into left and right channels. Most TV programs and recorded materials have stereo audio. The word Stereo appears in the channel banner when you tune to a program that is broadcast in stereo.
Sound Mode Provides special processing through your speakers (depending on the setting you chose as your Sound Type). The available sound modes are:
Off Does not give any special sound processing.
SRS WOW Gives a surround effect with more bass. (available for models L42FHD37, L46FHD37, and L46FHD35) SRS TurSurround XT (available for models L42FHD38, L46FHD38, L52FHD38, and
L40FHD380) Dynamic Bass Improves bass output. Displays a choice list of available settings you can adjust: Off and On.
Balance Press the right or left arrow buttons to adjust how much audio is sent to the left and right speakers.
Auto Volume Level Reduces the annoying blasts in volume during commercial breaks, and also amplifies softer sounds in program material. Eliminates the need to constantly adjust the volume.
Internal Speakers Turn on or off the internal speakers. If you have a device connected to the AUDIO OUTPUT jacks on the back of the TV and you want to control the sound by the device instead, uncheck the box.
If you would like for me to send you the user manual, please send me an email to LBrown18062@hotmail.com. Put "RCA L46" as the subject and I will send it to you.
Mar 30, 2012 | RCA L46FHD2X48 46 in HDTV TV
How do I wire up my Logitech X540 Speaker system to my Lg tv?
Most TV's nowadays, have audio out RCA jacks that will allow you to send audio from the TV, to an alternate source. These speakers do come with an adapter that allows you to hook up RCA red and white audio cable, and plug them into the adapter, which goes from the RCA jack to a 1/8 in female headphone style jack. You would then need to get a 1/8 in audio cable that has two male ends, and plug that into the back of your sub woofer in the front speakers port. But this really isn't going to give you very good sound quality being it's not giving you true 5.1 surround sound, even with the matrix feature enabled!
Dec 27, 2010 | Logitech X-540 Computer Speakers
There is no volume on the tv, the volume bar goes all the way to 99 but there is no sound, i plugged in external speakers it worked but the tv volume is not working. How do i fix this problem?
Go into your Audio menu on the TV and make sure the TV speaker are set to “ON”.
If the external speakers work when connected to the TV and the TV’s internal speakers don’t work when you remove the external speaker’s plug from the TV, then you will need to replace the main board.
The main board has all the function for the audio for the internal speakers. This was a known issue for some of the LG TV’s. So if you call LG about this issue, LG may fix it under a warranty.
Good luck.
May 21, 2010 | LG 26LG30 26 in. LCD TV
I cant turn the tv speakers on
You should be able to go to the main menu and select the setup menue, from there you should see the internal tv speaker option. Here isthe link to the manual: http://www.specsserver.com/CACHE/FRATSISBGCNF.PDF
May 20, 2009 | Mitsubishi WS-65819 TV
I have picture but no sound
go into the audio menue to turn speakers back on
Dec 27, 2007 | JVC AV-56WP30 56" Rear Projection...
Speakers
Tvs are wired differently these days. Your old Zenith for example probably had a selector switch that allowed you to change from internal or external speakers, bandpassing the audio from the internal amplifier to the audio out connectors. Your Sharp on the other hand may be controlled by customer menu to perform the same function as the external switch. Go into the menu and sub-menu of the audio and see if it gives you any choices for selecting internal or external speakers... If it doesn't it probably will not bandpass the already amplified signal, which means if you want to listen to your Tv on those external speakers you'll first have to pass the audio sample through an amplifier.
Hope this helps.
Bill
Nov 14, 2007 | Sharp 25N-M100 25" TV
Mitsubishi WS-65909 65" Rear Projection Television Logo
191 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
