Question about Dell Latitude D505 Notebook
Battery not charging. i have changed the battery and charger,stil
After changing the mother board, purchased a new battery pack and tried charging but the result is the battery does not charge at all. the message says the charger cannot recognized the battery pack
  • 458 Answers
Run A BIOS UPdate For Your Make/ Model...
Your Laptop Doesnt want to recognise it because it is not an OEM part... BIOS Update should have a fix in it for that.
Posted on Nov 17, 2008
Power-pack not charging battery
bad connector on pc or received bad power/charger unit try getting new charger to verify
Aug 08, 2014 | Toshiba Satellite T215DS1150 Netbook
I have toshiba satalite A300-20T and when i connect it with charge it restart but when i use battery only it work good
HAve you tried with another charger? before changing motherboard i suggest you to check your laptop with other charger. if it'll work then you don't need to pay huge amount to replace mother board. If it is with mother board then surely it;ll work if you change it but be sure before doing it. so check with other charger.
Jul 29, 2012 | Computers & Internet
I have a Panasonic CF_72 toughbook it is no charging the battery, I bought a new battery and have power to the mother board but it's not getting voltage to the battery to charge it. I was told there is...
This is just a suggestion, but some Dell Computers use an AC adapter which sometimes power the computer but do NOT charge the battery pack.
Simply trying another different power supply or AC Adapter will fix the problem without changing the voltage regulator.
I hope this corrects your problems.
Good Luck and regards from:
Richard, Montreal Based Panasonic Canada Toughbook Authorized Dealer since 1989.
Oct 24, 2017 | Panasonic Toughbook 72 Notebook
WHEN TRYING TO CHARGE IT WILL DISPLAY CHARGER NO AUTHORIZED AND IT WILL REMAIN AT 3/4 GHARGE.......??????
change your charger because sometimes the charger gets faulty and cannot provide the required amount of current to the battery. Second reason is not using the original charger so in both the cases you have to get a new charger to solve the problem. If the problem stil remains, then contact the customer care centre
Sep 18, 2010 | Motorola Mobility VU204 Cell Phone
Blue light on, battery won't charge, unit new 12/14/09
rechargeable batteries are definitely a better bet. I have used many Wii battery packs and chargers, none seem to last very long.
Jun 05, 2010 | Nyko Wii Fit Battery Pak for Nintendo Wii
It will not charge
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. click here Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. 5. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models. click here
Aug 16, 2007 | Nokia 6111 Cellular Phone
Dell Latitude D505 Notebook Logo
303 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
