I have a Sager D8P laptop, For some reason I cannot get the laptop to turn on. It has a new power supply and when I press the power button, it makes noise like it is turning on, but nothing appears on the screen. Any idea?
  • brunhold Nov 17, 2008
    hi,
    thanks answer.
    This laptop has no battery that I can try out. When turn on, fan works, lights on and NO screen.
    Screen not turned down.
    Ac adapter has been changed (no idea why) and seams like AC adapter work ok.
    Thanks
  • 408 Answers
The video card may have went out.The screen itself rarely goes out.its either videocard,video inverter or a loose video cable.The D8P has a tendency to overheat when the cooling fan is either not working or is blocked or dirty.Try unplugging the video cable with it powered off,then plug it back in.Maybe you will get lucky and it will work.If not i would say the videocard is damaged.
Posted on Jul 27, 2009
    Sergeant:
  • 237 Answers
By power supply, do you mean a new battery or a new AC adapter? When the noise comes, are the status lights on on the laptop, battery and ac adapter?
Plus: check the lcd settings---is it turned all the way down? This could be the easy solution.
Posted on Nov 17, 2008
  • zabrina liang Nov 18, 2008
    I think what you are trying to tell me is that the screen is blank, and not showing a thing because you say the AC Adapter works. In which case, you will have to get the screen repaired. Anything else I can help you with?
NY Samsung laptop turns on, but only a blue screen appears. The green light on front of laptop isn't coming on.
This sounds like the Blue Screen of Death. Most likely a hardware problem. Does the blue screen display words and numbers? If so try to write down numbers and do a Google search. This should give you a good starting point. Or send me a snap shot of screen and I\'ll see what I can come up with. Hope this helps.
Jan 16, 2015 | Samsung Series 5 Ultra 530U3C - Ultrabook...
My Sager NP9860S was working fine and all of a sudden shut off. There are no lights on at all on it. The external power supply led is dim and blinking. When I unplug it from the laptop, the led is on...
where you having any issues before this happened?have you tested the memory,checked ram seated correctly,hard drive, cables all properly fitted?
remove the battery from the pc and the power cord.
then press the start button for one minute to discharge all electricity from the motherboard.
then put the ac cord back in and wait 10 seconds.then press the start button.you may have a faulty battery so try the ac cord procedure first.
i also understand this is a gaming machine.check your video card!
Mar 13, 2011 | Computers & Internet
I cant turn on my HP520 notebook pc. when i press the power button, it blinks once, and the charging light blinks for 9times(orange light, the 8th times was green light) i tried to remove the battery and...
Alright, not sure if this will help, by my understanding is that you are saying that when you power the computer using the power supply adapter, nothing comes on? Then when you have your battery installed on, then there are lights blinking from your battery charger LED amount of times. In this case there are no promblem with your laptop and it is your power supply adapter that is damaged and will need to be replaced. It is not charging the battery. The battery is still good, but does not have enought charge to power up your system. You can find a charger on ebay for a good reasonable price compare to getting it from Hp. I hope this can help you.
Jan 13, 2011 | Computers & Internet
WHERE CAN I FIND A D8P VIDEO CABLE
I thought that one could find anything on eBay,
but the _closest_ that I can find is a 'D8P' notebook computer:
http://cgi1.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=350361649975
Tell us more about what part you need, and how & to what it connects.
Jun 01, 2010 | Computers & Internet
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
1. Turn off computer and unplug power cord.
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
This should work....all the best
May 19, 2010 | Computers & Internet
Hp pavilion dv6775us will not power up.
These are the reasons why your pc wont switch on
1. Defective power adapter
2. Defective Processor
3. Defective Motherboard
Note: If you replaced your motherboard check the specs on the previous motherboard it should be the same part number or a replacement part number.
You can purchase your motherboard to HP System Board HP Motherboard
Here's a sample video
Feb 13, 2010 | HP Pavilion dv6775us Notebook
Laptop wont start up/POST
if even bios doesn't boot up...den its the motherboard problem..since its just few months old system it should b under warrenty...
May 22, 2009 | Sager NP-5620-S Notebook
Toshiba satellite p105-s6217 will not power up or charge.
Larry,
  1. Unplug the laptop and remove the battery.
  2. Press the power button down and hold for 10 to 15 seconds.
  3. Press the power button 5 more times quickly.
  4. Plug the power back into the laptop without the battery and press the power button.
If the laptop powers on just put the battery back in.
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Sager d47v no video
It could be a lid switch. Get it on long enough to go into the power settings, turn the option of "lid closed" to "do nothing". If this does not help there are only 2 other things affecting it. 1. cable, internal to the machine that may be bad or 2. The video card on the MB itself. If its the latter, you will need to replace the MB or probably be cheaper to buy a new laptop.
Sep 17, 2007 | Sager NP-5620-S Notebook
Computers & Internet Logo
225 people viewed this question
Alun Cox
David Payne
David Payne
