Question about NEC PlasmaSync 50MP1 50 in. Television
Monitor shutting off with blinking standby light.
My PlasmaSync 50MP1 monitor shuts off after a short period. The standy light then blinks continuosly in the following pattern: green green green red green green red ... Any ideas what's wrong? Is this easily fixed (low $)?
    Problem Solver:
  • 9 Answers
I can guarantee to fix this tv for $400-900. I have all good boards and know the procedure to determine which board is bad.
Posted on Nov 22, 2008
  • 103 Answers
Very expensive to fix.You hve a bad ysus board.Nec will re-build theboards as a set 1000.00 plus
Posted on Mar 22, 2007
SOURCE:
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
Problem with the Philips 42PF9431D/37 The screen won't come on and the power light blinks green for a few seconds then to red blink
1- bad scaler bd. 2- short or open fuse on t-con bd. disconnect lvds cable from scaler bd. to bd. on back of panel if stays powered u got it solved 3- swollen capacitors in power supply
Sep 09, 2010 | NEC PlasmaSync 50MP1 50 in. Television
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Jul 17, 2010 | Acer Computers & Internet
Where do I find speakers for my NEC plasmasync 50MP1? The unit our CEO has does not have on-board speakers, but utilizied ceiling mounted speakers. It was recently moved to a new site and the speakers were...
This monitor has onboard amplifiers and external speaker terminals which can be connected to any set of speakers. The amp puts out about 7W per channel. There are attachable speakers made for this monitor (model PX-50XM1U-S1) which you may find as well.
Hope this helps,
Dan
Apr 30, 2010 | NEC PlasmaSync 50MP1 50 in. Television
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Jan 21, 2009 | Marantz SR6001
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
TV turns itself off.
if you now how to used soldering iron , resolder your tv
Oct 22, 2008 | Televison & Video
NEC PLASMA SYNC 42MP2 STANDY BY MODE?
According to the manual for "POWER/STANDBY indicator is blinking in red":
  • "The temperature inside the main unit has become too high and has activated the protector."
  • "Promptly switch off the power of the main unit ans wait until the internal temperature drops."
  • "If the monitor becomes too hot, the overheat protector will be activated and the monitor will be turned off. If this happens, turn off the power to the monitor and unplug the power cord. If the room where the monitor is installed is particularly hot, move the monitor to a cooler location and wait for the monitor to cool for 60 minutes."
Feb 04, 2008 | NEC PlasmaSync 42MP3 42 in. Television
TV will not stay on for longer than 5 minutes
This sounds like the shutdown circuit is shutting down the TV due to an over current condition. This overcurrent condition is caused by a component in the HV section drawing excessive current. the 5 blinks is a visual indication of the problem.
Sep 08, 2007 | Sony KV-36XBR400 36" TV
NEC PlasmaSync 50MP1 50 in. Television Logo
598 people viewed this question
Top NEC Televison & Video Experts
Kyle Steven OHare
Kyle Steven OHare
Jerry Greenberg
Jerry Greenberg
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
