Slow transfer from SATA II (IDE) drive to 3 SATA II Drives configured as RAID (1). Drives wouldn't format until we installed the OS onto the RAID -- but it wouldn't install completely. We boot from the independent IDE SATA II drive but when we try to then copy files back to the formatted RAID (1) configuration the copying is very slow. Drivers from Tyan are updated (both chipset and SATA RAID) and we have set the drives to various configurations -- BIOS contoll, PIO, and DMA.
    Problem Solver:
  • 9 Answers
It appears you have made an error with the RAID configuration. RAID 1 is mirroring and requires an EVEN number of drives unless one is a hot spare. Also, RAID 1 is for redundancy and is slower than a single drive or RAID 0. Verify your RAID configuration and make sure you have RAID 1 and not RAID 0 or RAID 5 which can be an even or odd number of drives.
Posted on Nov 17, 2008
Can i just hook it up and run the disk wizard? or is there another formatting ,partitioning tool I should get?
Use Disk Wizard. No 3rd party tools are required at all.
Scenario: 1 Pipeline SATA. 1 Barracuda SATA. 1 IDE drive with current OS. Is this correct?
Just treat the Pipeline from the DVR as an extra drive by formatting it, and moving the files over. You then can remove the IDE and Pipeline for peace of mind, but the OS advance setup should give the option of all three drives for install destination.
Leaving the IDE drive should not affect your resources.
Oct 25, 2012 | Seagate Technology 500GB Pipeline HD SATA...
I have a Dell Optiplex 170L mnitower. It has one IDE and one SATA port. I have connected a 1 TB drive to the sata and disconnected the ide drive that came with the system. No I am thinking, what if I add...
Hi there! You don't actually need a IDE to SATA converter. If you purchase a RAID 1 card, it gets hooked up to your computer via PCI or PCI-E. The RAID card will have at least two SATA ports on it - those are what you use to create your RAID. The sata port and ide port on the computer will not be used in the raid1 configuration. If you're going to go ahead with this, I'd recommend trying to find the exact same brand and model of drive as the first one you have. Also, keep in mind that creating a RAID 1 array requires formatting BOTH drives. Your Optiplex 170 only has PCI ports, so this may be a viable RAID card. It is fairly inexpensive, but will do the job. http://www.newegg.com/Product/Product.aspx?Item=N82E16816132001&cm_re=PCI_RAID-_-16-132-001-_-Product If you need any more help/advice let me know! Alex
May 30, 2011 | Computers & Internet
I am using a single SATA II Drive in a new system, GIGABYTE GA-MA790X-UD4P, AMD 790X & SB750 chipsets. I know I can let the SATA II be a "Native IDE" but isn't that loosing any benefit of the SATA II...
The "Native IDE" mode causes the motherboard to "report" to the Operating System that the installed SATA drive is an IDE drive, rather than reporting "no IDE drives installed", and then requiring the Operating System to load a SATA device-driver to interface with the SATA drive.
Using RAID to "mirror" your hard-drive is a very-cool way to provide a "real-time" and "up-to-date" backup.
Should one of your drives suddenly "die", the other will continue to work, and you can buy another hard-drive, re-establish the "mirroring", and continue to work productively -- no fiddling with offline/stale backups.
Sep 18, 2009 | Gigabyte GA-MA790X-UD4P Motherboard
ASUS P5LD2 Raid 5 locks windows at MUP.SYS
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the  IDE  slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
Software raid/ide
it won't touch them, it should ask you which partition you want to boot from, or which version of windows if your boot.ini files are on the same drive.
Dec 18, 2008 | Computers & Internet
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
HOW TO CONFIGURE RAID
I needed to see your board & can at this site. http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=493&DetailName=Manual&MenuID=1&LanID=0
This is good for you as well. It shows me & you that your board can handel 4 each DMA/ATA-133 (Ultra) IDE Hard drives/ CD/DVD drives IDE-1Primary & IDE-2 Primary Slave. Each can run 2 IDE drives. Also 4 each Serial ATA SATA's. Two separate SATA controllers with integrated PHYs, each supporting two
drives in master mode. In your manual on pg.32 & 33 will help you to setup a RAID if you wish. Or you can also set the RAID to IDE which will allow you to use all your SATA hard disks as a single drive without setting up a RAID system. The site above supplies all your drivers needed & manual. If you need more help please let me know here.
Luck!
Please vote......
Jan 13, 2008 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Sata , ide
Initially connect only the sata drive from which you want to boot the OS. Establish the OS successful operation from this drive. Then connect the remaining drives in conventional way or the RAID array you want to have.
Oct 25, 2007 | Computers & Internet
Asus P5K-E Wifi/AP configuring sata as raid
Hello to start with.
Here are a few specks from me to start with.
1) E6850 core duo 2 x3ghz
2) 2 gig Corsiar Ram 4 4 4 12 timings 2.10 v
3) XTX 8800GTS 512 mb ddr3 ram
4) HD321KJ Samsung Sata II 320gig
The SATA II drive doesnot and i repeat not have a problem in windows. Everytime you recieve your blew screen go straight into bios and then tell me what you see on the first screen it shows for one your sata drives and the positions please refer to user manual for postions. At the moment in my config it should show on port 2 my hd321, but sometimes it failes to find the drive.
Now you try and Put windows onto your drive.
This is were it gets critical what with all the new starts remember in bios sometimes it doesnt find the drive BIOS needs to be updated. Windows works fine untill such times as you put stress on the hard drive because then it will loose the plot somewhere.
Once you have got to that position the board then shows what its been baught for Crysis was all on hi in graffik department anti alaysing x4 and the resalution 1298 960 and it played like a dream.
I also play Battlefield 2 + BF2 special forces inclusive patch 1.41 .now the stress starts for the drive BF2 no prob BFSF2 the machine just cant handel the info a blue screens press reset and go into bios no drive wonderful. Its been like that for the month my solution is simple and not very expensive PCI e SATA II + IDE Buss card.
I hope i havent put anyone of this board for that is not my intention the board it self is a dream peace of work. Windows for once is not to blame but please the driver Dudes come on sort this conflict out.
icon_cool.gif Crowley icon_cool.gif (An Angel who did not so much Fall as Saunter Vaguely Downwards)
Oct 14, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
269 people viewed this question
David Payne
David Payne
