Question about HTC G1
G1 SD phone can not identify sd card, after the update it erased
  • 6 more comments
  • Anonymous Nov 27, 2008
    same here, even,when it sumtimes poops up in windows(by using card reader)
    nothing
    (did even the eject method ,while having it in cardreader..then when in phone inserted,nothing
  • breck3957 Dec 04, 2008
    My G1 does not read my SD card; cannot use camera.
  • Anonymous Dec 06, 2008
    the sam as above
  • Anonymous Dec 07, 2008
    same
  • blackpearl66 Dec 10, 2008
    My G1 no longer recognizes the SD card. It worked fine up until about 3 days ago.
  • Anonymous Jan 16, 2009
    same
  • Anonymous Jan 22, 2009
    my g1 dosent reconize my sd card
  • Anonymous Feb 24, 2009
    sd card unreadable
  • 97 Answers
If reemoving and reinserting the card doesnt help, youll need to have it reformatted....
do this by connecting your phone to the pc and opening your MY COMPUTER icon > right click REMOVABLE STORAGE/DISK > select FORMAT
**if your computer says something like 'no disk available' try disconnecting the device and select MENU > SETTINGS > SD CARD AND PHONE STORAGE > make sure the check bos for 'USE FOR USB STORAGE' is checked****
after that, set the 'file systems' as FAT32 > select START > read the warning > press OK > once complete, disconnect from the pc and try again!
IF that doesnt work, try to test the sd card in another phone to see if the sd card itself is the problem. if you still have the issue but the sd card works, go ahead and reset the phone.
MENU > SETTINGS > SD CARD AND PHONE STORAGE > FACTORY DATA RESET > RESET PHONE > ERASE EVERYTHING
Posted on Jan 28, 2009
I have a g1 and it downgraded to 1.0 how can I upgrade it without a manual update
How to Update G1 Phone Firmware RC33
1. Download RC33 update from Google here.
2. Rename the download file from signed-PLAT-RC33-from-RC30.f06aa9b3.zip to update.zip, and place it at the root i.e the very top directory of your Micro SD card. (If you added the file to your microSD card by connecting the handset to your computer via USB [rather than using a dedicated microSD card reader], make sure to unmount it and disconnect the USB cable now.
3. Turn off your G1 Make sure it's completely powered off. Now again turn it on by holding the Home+End keys until you see T-Mobile G1 logo.
4. From the icon screen, open the keyboard and hit Alt+L.
5. Press Alt+S to begin the update. Remember, the update needs to be in the root of the Micro SD card and needs to be named update.zip.
6. Once it finishes, follow the onscreen instructions and press Home+Back to finish.
7. G1 Phone will reboot a few times to flash different parts of the firmware.
If all went well, you should now be running the latest update, RC33. Enjoy your new, shiny RC33 update, complete with Google Latitude!
To make sure all your hard work wasn't for nothing, hit Menu > Settings > About Phone > scroll to Build Number. You should see RC33 in there somewhere.
Mar 23, 2011 | HTC G1
Hi, my g1 has problem to read the sd card, when i try to use the camera, the phone says it does´nt have, and windows XP do recognize the phone
Need a little clarity on what your saying XP does recognize the SD card when you mount the phone to the computer, or it doesn't?
Well here is what you can try. and just remember ALWAYS ALWAYS ALWAYS do this before removing your SD card from your phone.
Settings>SD card & phone storage>Unmount SD card
Now if your phone has "Unmount SD card" blacked out then don't worry about just go ahead and remove the SD card.
Take the card and put it in a card reader and put it in your computer. Go to: Start>My computer> (and the drive corresponding to the SD card.) and then try to open it. If a window comes up saying something like drive E: is not formatted, Format now? and then Ok or cancel well if this comes up it could be one of three reasons; the SD card is not properly formatted, SD card is damaged, or the SD card reader is not working properly. So before trying to format the SD card try another card reader or try it on a different computer. If that doesn't work try to format the SD card. If formatting the SD card doesn't work, you may need to buy another one. If you do decide to get another one check Amazon.com they have good prices for the SD cards however if you prefer local buying best place to go (that I've found) is Radio Shack. They always have sales on the MicroSD cards. One other thing. For some reason. SanDisk Micro Sd cards seem to work the best for the G1. The transend cards are utter **** and worthless. Avoid buying them anytime your in the market for a new SD card or USB flash drive.
If you need further help feel free to check out xda-developers.com
Aug 07, 2010 | HTC G1 Smartphone
Keeps saying sd card removed when its clearly in!!
i recently bought a used g1 from a friend and tried to insert an sd card but it said the same thing sd card removed the card is fine then i did some researching and found out that the q1 has a sensor in the sd card cover which if it is opened it will say that message now my problem is that the cover is broken so i am currently working on a solution to that but if it is not broken then just try taking the sd card out turn off the phone and insert the sd card and properly close the cover make sure it is not opened even the slightest then turn your phone bak on and it should work unless the actual sd card reader is damaged or the sd card itself. hope this information was helpfull
Feb 28, 2010 | HTC G1 Smartphone
SD Card In G1 Retrieving info
i took my sd card out and rebooted my phone and everything is gone... how can i retrieve the info
Jun 25, 2009 | HTC G1
I have a g1 and I don't kno how to put pictures or applications on my sd card. Does it do it by itself or do I have to download something and how do I do that?
To put pictures on your SD card all you need to do is attach the G1 to your computer, mount the SD card when the notification comes up on your phone, and then copy and paste any pictures you want onto it. However, you can't save applications on the SD card, they are saved in the phone memory when you download them from the Android Market.
Feb 17, 2009 | HTC G1
Sd card
I had the same problem. so what i did is i created a back up on my computer and format it the sd card. and it had a bad file in it that was causing the problem. once i format it the card it was ready to be used again. just make sure you look for that corrupt file so you don't put it again to the already clean card. also i removed the sd card from the g1 and plugged it straigt to the computer. I hope this can help you like it helped me.
Feb 12, 2009 | HTC G1
Transferring stored data from micro SD card on G1 to new one
plug your G1 to your PC via a USB cable that came with it .., once you plug it in you'll get a notification entitled USB connected .. select it and then choose mount ... once thats done open your My computer icon , you'll see an exrta drive that wasn't there be4 somethig like K or M .. open that and you'll see all the content of your SD card .. copy and past everything to a folder anywhere in your computer ... then all you gotta do is replace the SD card , repeat the same proccess but then time copy everything back to your new SD card .
Jan 30, 2009 | HTC G1
G1pictures and video saved to my sd card automaticly delete
hey, your g1 not deleted your videos, u find the rigth format 4 your videos n' see'll
Dec 28, 2008 | HTC G1
Option to use SD card as usb not available
I found the solution to that problem its because something was deleted when updated but heres how it works. first connect usb to phone and then connect usb to computer as soon as you do that on your phone select menu and then select notifications and then usb connect and everything should be fine.
Good Luck.
Nov 15, 2008 | HTC G1
Camera will not read SD card
1.) Mount your camera
2.) Open your dcim folder in your camera
3.) In whatever file browser you're using (Explorer, Finder, Nautilus, etc) enable show hidden files.
4.) Remove .thumbnails folder
5.) Be sure to empty trash
See if that works.
Nov 03, 2008 | HTC G1
HTC G1 Logo
581 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
