Question about Magellan MAESTRO 3100 98083401 GPS Device
My magellan maestro 3100 gps is lost
Hi. I have a Magellan Maestro 3100 gps. It worked fine on a recent trip, and then, suddenly, failed to update its position. It still "thinks" it is somewhere a couple hundred miles from here. All other functions seem to be working normally as far as I can tell. One can still program addresses, calculate routes, etc. The problem is that the GPS just doesn't know where it is. How can I get it to update its position?
Thank you,
Leigh Ann Kern
(530) 894-2499
  • 1,011 Answers
Dear Sir/Madam,
Click this link for more information and here is the update.
good luck
Posted on Nov 17, 2008
  • 181 Answers
Did you changed any settings from the orignal  setting adjusted .
  • 1 more comment
  • fixyy Nov 17, 2008
    1. Unzip downloaded file
    2. Use WinRAR to extract the executeable (they will all be in a file)
    3. Create USBTRANS file in SYS folder on unit (or copy the backup that was made on the SD card)
    4. Copy contents of COPY_GROUP 1, 11, 13, 17 to SYS/USBTRANS
    5. Copy contents of COPY_GROUP 2, 3, 5, 7, 8 to MAP
    6. Copy contents of COPY_GROUP 4, 6, 12, 14, 15 to APP
    (NOTE: in order to copy over group 14, you will need to copy the contents of TNShell_Bitmap\Venus2 to the same folder on the unit, that way the folder isn't just replaced)
    7. Copy contents of COPY_GROUP 9 and 10 to SD card
    8. Copy contents of COPY_GROUP 16 to USR
    9. Once copied over, unplug the unit and it should reset itself. Then all should be working
    DON'T FORGET to put in the UNIT_ID.DAT file back in the USBTRANS folder if you haven't already.
    if the updated thing does not work try this if u have a reset button in your device mostly every GPS has this button
    No need to worry about that this problem arise when the unit is not piciking up the signal.In that situation what you can do is ,you can do a small reset to your unit . In the left hand side bottom corner you can see a small pin hole named as reset .What you have to do is turn on the unit and insert a paper clip in the reset hole and gently push it inside.So the unit will be reseted surely 100% it will show your location...
    just click on this link for more detailed help with step by step directions.
Magellan maestro 3100 stuck at bootup screen
did that just happen all of a sudden or did you try and update the 3100 and it failed to boot after that...if you didnt try to update it...turn the 3100 on then use a paper clip to depress the reset on the left side bottom of the gps and let it restart.
if that fails, let me know and ill help you further
Jul 15, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Hi My Magellan Maestro powers up with the Magellan screen and the bar scrolls but thats all it does? Carl Lucas Aberdeen MD
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Aug 03, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 model suddely stop speaking and how can I add new maps?
make sure you have the latest firmware update by checking the link below and also you can purchase map updates there also.
Jun 13, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
have you updated the maps on it? if no try and update the maps also do a firmware check to see if you need an update.
Nov 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 failed update
go to Tech support at tell them what has transpired and ask for 2.18 Update Recovery Files. This fixed my problem. Took a few email exchanges but I thought the responses were very quick.
Oct 04, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan GPS
Online at Magellan website you can update your magellan maestro 3100
Mar 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3100 stuck on
If you followed the procedure closely, you now have an SD card with your backup on it. The backup consists of two folders: BACKUP, and USBTRANS. Insert the backup SD card in your PC's reader slot and open a "file explorer" aka "Windows Explorer", not to be confused with "Internet Explorer". You will use Windows Explorer to click and drag the USBRANS folder to the Maestro.
With the Maestro 3100 connected to the PC, a couple of Explorer folders will open and you can see the file structure for the GPS in 1, and in the other one a separate file structure for the blank SD card needed for the update. Look at the file structure for the GPS and you should see a handful of folders including "SYS".
  • Start the upgrade program, following the procedures.
  • Click the NEXT button at the bottom of the procedures screen.
  • Immediately copy the backed up USBTRANS folder (and all contents) to the SYS folder on the GPS.
  • The update should now find the Maestro 3100 and proceed with the update.
SUMMARY: copy USBTRANS (it should contain 1 file: UNIT.DAT)
  • from your BACKUP SD card (not the one in the Maestro)
  • to your Maestro 3100's SYS folder.
Feb 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan MAESTRO 3100 98083401 GPS Device Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
