Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Won't power up
I have a problem with my tv, when you hit the power button it just clicks,and won't turn on, I sent in the main boards and had them rebuilt, and it still does the same thing the standby light flashes 6 times, any help at all would be greatly appreciated!!!
  • the waco kid Nov 04, 2007
    When you hit the power, the light flashes 3 long and 7 short flashes. Then it flashes 6 flashes. This is repeated for as long as the supply is there. I have replaced a cap that appeared to be going out to no avail.
  • 143 Answers
Well this sounds like your power supply check fuses and horizontal transistor check to see if all connections are good get back to me
Posted on Nov 02, 2007
Why does my tv not turn on when I use the power button?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 05, 2015 | Televison & Video
How do I test my main board in my 42 LG LED TV?
Testing the board is too complicated to try to explain in this forum. If the tv won't turn on with either the remote or with the tv buttons, the main board is failed and needs to be replaced. I have gotten some tv's working by replacing the EE prom on the main board, but finding the proms is hit and miss. Go to ShopJimmy.com and see if they happen to carry one for your tv.
Mar 17, 2015 | LG Televison & Video
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
1990 panasonic tv model# CTM-2783S won't turn on
the tv need for servicing, the cause is either bad regulator transistor in the power supply section or shorted horizontal output transistor. that is why the main circuit board doesn't get to turn on. to do the repair just ensure you have knowledge in repairing tv.
Nov 17, 2012 | Televison & Video
Power button won't turn tv on. light keeps blinking on and off
Main board to your TV is faulty. Check the chroma and video processing section. In most cases, it will be due to an IC fault.
Jul 23, 2012 | Curtis-Mathis Televison & Video
HDMI/ DVI inputs failed approx. one month after connection of Denon home theater receiver with HDMI pass-through feature "on." Gear successfully re-connected via component video...
hi welcome to fixya
i want to clarify first the problem sir so as of now the problem with your tv won't power on then you are using again the old main board is that right ? when you use the new replacement main board the tv is functioning will the only problem is that the HDMI / DVI inputs doesn't work. and now you encountered power supply problem like won't start up or something that cut the supply in which the stand by indicator is turn off so as my idea it has a problem with the old board. but before you come up with the board making sure all the connectors coming from the power supply is properly connected to the main board as will as flexible and lvds cable for the T-con board is properly inserted.just let me know if is that what you are asking for so i can give you additional solution thanks for consulting the fixya.
Aug 30, 2011 | Televison & Video
The tv just suddenly stopped projecting video and sound. Now can't get tv to come on. When I unplug it from the wall and plug it back in the green light at the bottom is on and when I hit the power button...
1.You have a power supply issue on the main board of the TV.
Your TV will need service.
2.the inline protection fuse or the rectifier circuit has malfunctioned ( weak or bad) component and need replacement parts.
3. the clicking sound is the start up circuit but the voltage signal sent to the next circuit is not received therefore the system in not activated.
Feb 05, 2010 | Sanyo DP42746 42 in. Plasma Television
Polaroid tlx-3210b tv will not turn on the red light comes on and the blue light comes on when you hit the power button but still no picture or sound have to unplug tv to turn off blue light. contacted...
Symptom shows that Mani Board is bad in your TLX-03210B Polaroid TV and need to be replaced. I do not see problem of capacitors in power supply board. Problem seems in system control section of TV that is located on main board.
Click Shop Jimmy as it is best source to obtain boards of LCD TVs.
Please call Shop Jimmy for main board availability as currently its out of stock.
Hit "add a comment" button for further query / info.
Thanks.
Apr 30, 2009 | Televison & Video
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
