Question about Jeep Car Audio & Video
C/D locked in,can't eject
I have a 2005 Jeep Grand Cherokee , the radio works OK but the C/D player doesn't. I put C/D in and it locker up. I can not eject the C/D. Also the radio C/D face plate gets very hot to touch. Ihave installed a new deep cycle battery and it goes dead. Is this related to the radio C/D player problem? Thank you for your help
  • neelvy May 16, 2009
    I have the same problem? I just installed a new battery into my 2005 Grand Cherokee Laredo.
    Now my CD player doesn't even come on when I press the mode button. It won't eject the disc when I press the load button. The radio works fine however.
    Also, when the car is off I can hear the disc changer making noise like a disc is stuck. How do I reset it or get the disc out if I can't even get to the CD player screen?
  • 199 Answers
Hi, the mechs on thease units do tend to jam up. it will need to be manually reset, ie cd removed and set to eject state, as for panel gettinghot. thinks it normal
mark
www.blueice-electronics.co.uk
Posted on Nov 25, 2008
I am not able to switch to cd player in my 2005 grand cherokee radio
is bad, the CD drive is bad.
you have choices.
1: check all fuses.
2: replace it. $$$$$$
3: get it fixed $$$$$$$$$$$$$$ ($50/hr x4 ? and parts, nah....)
4: dismantle it, and unjam it , clean it, make sure no broken CDs in sided or labels fell off inside, or other alien objects inside, blow it out.(canned air) (silent prayer?)
4: upgrade to a head end with USB port and run USB mem stick with 1000 of songs off a stick the sizes of a Chiclet gum.
id go with #4, upgrades are a big win..
Apr 30, 2015 | 2005 Jeep Grand Cherokee
Radio in 2003 jeep grand cherokee does not play cd's. it plays the radio stations, volume works, but it does not eject the cd or even recognize it .
you can look for a radio shop to repair the cd player it would be cheaper to install a aftermarket radio they do have kits if you have steering wheel controls
Apr 10, 2012 | 2003 Jeep Grand Cherokee
I have a 2005 Jeep grand cherokee...with a 6 disc cd player. It has worked fine for 3 years since i bought the vehicle...(i used burned cds in it usually) and all of a sudden it will not play or read the...
this is a typical problem with the factory stereo. usually there is nothing you can do for the Cd player, because most likely a cd got jammed and broke or bent some internal components. however try usig a credit card to help eject. insert it partially into the slot and pull out if the cd tries to come out. if this doesen't work then you will have to have the cd removed by tearing it apart. this usually ends up with at least one or two scratched cds and a deck in a million pieces.
Jan 18, 2011 | 2005 Jeep Grand Cherokee
My Cd player in my 2004 Jeep grand cherokee laredo wont eject the cd. It recognizes that there is a cd there and will even play the cd when i press the mode button but it wont eject it. Any help is...
I have an 05 jeep grand cherokee and the other day when I went to hit the the eject button on the CD player it automatically went straight to the radio. After I restarted the vehicle I could hit mode and it would begin to play the cd again but if I tried to hit eject it would go to the radio again. It doesnt have a disc changer and everything else on the factory head unit is working find, the radio, all that stuff. I didnt want to start tearing things apart or trying to dig it out. I have sees some others with the same problem on here, but the answer are like "dig in there with tweezers" and I dont think thats the best possible way to solve the problem. Any Ideas?
Aug 25, 2010 | 2005 Jeep Grand Cherokee
Jeep cd player says error
Cd player wont play or eject the cd.
Oct 25, 2009 | Jeep AM/FM Cassette with CD Changer...
Eject navigation disk in 2005 Jeep Grand Cherokee
Under the cd slot you will see a long thin rectangle that can be gently pryed out with a knife tip on the right side of the rectangle. under that cover there is a small button. push that and out comes the nav disc. Voila solved
Feb 10, 2009 | 2005 Jeep Grand Cherokee
2002 ford escape liftgate wont lock/unlock
the electronic sensor could be bad or the lock is physically jammed.
Feb 09, 2009 | 2001 Jeep Grand Cherokee
There are two CD' in the player.
you have to remove the radio so you don't short out anything remove the fuse for the radio once the radio is out by taking off the face plate you should be able to remove the CDs without damaging your unit don't pry on anything and you can do it
Jan 18, 2009 | 2005 Jeep Grand Cherokee
2005 Jeep Grand Cherokee Problem
I would start by checking all the fuses under the hood.
There is a fuse called IOD which the factory leaves out and gets put in at the dealer.
That fuse could be bad.
Oct 10, 2008 | 2004 Jeep Grand Cherokee
Car Audio & Video Logo
1,060 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
