I'm having a problem recharging the battery in my e200. I have opened the back up and removed the battery and the e200 connects to the computer okay (though it simply identifies the device as a removable drive and not a unique device as it used to when I first bought it). I have a cradle and rechargers designed for it but none of them work to recharge though they work ok as wall adapters. Any suggestions?
"Removable drive" sounds like it got set back to MTC mode (USB mode in sansa settings menu). Needs to be in MTP mode to really be of any use.
I have the e280 and it recharges fine when it's hooked up to my PC. It might be the battery, the connection, or the player.
Also, it has to be a "high power" USB port on your PC (whatever that is). ie: If you're on a really old PC, there might not be enough juice getting through to the player. But if the rechargers don't work either.....
I was given a used sansa e250. I am using my sansa fuze cord to charge it and connect to the...
(More)
I was given a used sansa e250. I am using my sansa fuze cord to charge it and connect to the computer. Windows Media Player does not recognize the device. What do I do to be able to load some music onto it?
