E677 your solution is not working. When I press additional* 2+8 additional* nothing happens. what should I do?
  • 168 Answers
What machine is this that code means your external print controller is bad
Posted on Dec 07, 2008
Service Mode - Please help me!!!
HI , Check weather the copier are in normal mode or finished the running of processing .Or you can try reboot the copier and do it again .
Mar 09, 2012 | Office Equipment & Supplies
I have canon ir2000 photocopier machine and i t is showing e354
Canon IR 2000 copier is showing System Error E000
From my searches online the first course of action seems to be resetting the printer in service mode.
I attempted to clear it in service mode:
1. Press ADDITIONAL FUNCTIONS, #
2. Go to #7 Printer and press OK
3. Go to #4 Printer Reset and press OK
4. Yes = ( > )
However, when I press the yes (>) nothing happens.
Does anyone know why this is not working?
Apr 15, 2011 | Canon ImageRunner 1600 Copier
Ihave problem with canon ir 600 .Error show E677
E677 communication error between machine & pc.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | Canon imageRUNNER 600 Printer
Eror E677
roblem :
The machine displays an E674 code. This may be followed by an E677 code when the Fax pcb is removed. The imageRunner also has a Print Board installed.
Solution :
With the Fax Board and Print Board installed an E674 code occurred. When the Fax Board was removed an E677 code then occurred.
Try removing the PDL Interface pcb for the Print Board from the copier. Reinstall the Fax Board, if the E674 code does not occur and the copier is capable of sending and receiving faxes, then replace the PDL Interface pcb because it may be faulty and causing the two E codes; E674 for faxing and E677 for printing.
Jun 01, 2009 | Canon imageRUNNER 400S Copier
Ir400 e677 error
E677 on iR400 is the otional printer board assembly was trouble. It must be change. Try this : replace your optional printer board assembly, the problem was correct? The other day you must bought optional printer board assembly. God Bless You....?!
Feb 06, 2009 | Canon imageRUNNER 400S Copier
My IR 400S Photocopier showing E677 after working for 10-15 minutes.
First Print A configration Page
turn Off Machine
When You Starts A Machine Press Print Button
Wait.....
After That It Asks Run Setup.
Run setup
After That Go TO last Option Restore Default settings.
then ok
wait few menitus
Ins. aal config. in.
Nov 17, 2008 | Xerox Office Equipment & Supplies
E677
press the additional * 2+8 additional *
select the copier on the screen
select function
select clear
select ERR
press OK
restart the Copier
Oct 02, 2008 | Canon imageRUNNER 400S Copier
I have a Canon IR 330 with an error: E677 then it says to power off and power on which I have done to no avail. The error has a little wrench besides it
Error E677 is a problem with the connection between the printer board and the main board of the copier. Most likely the problem is a bad printer board, assuming no one has opened the back cover of the copier and the unit was working recently.
Jul 01, 2008 | Office Equipment & Supplies
PIP doesn't work
Do you have 2 tuners hooked up or an additional source playing?
Oct 23, 2007 | Hitachi 42HDT79 42 in. Plasma Television
50 people viewed this question
jasbo
jasbo
