Question about Microwave Ovens
GE MicroWave JES1136WL01 died while defrosting.
While  defrosting some frozen rolls for 33 seconds, the machine "went dead" after a few seconds, perhaps less than 15. previous  to this, the display indicated a power failure. I reset the clock & thought nothing more of it until the machine became unresponsive, no lights in the display or any thing.  I checked the breaker panel, found no problem, other appliances plugged into the outlet worked ok. switched outlets, no improvement. I can not find a "reset" button.  Any repair suggestions, diagnosis, comments?
Thanks for  your expertise.
 CE
  • whoisjgalt Jan 15, 2009
    Yes, mine also died (though not while defrosting.) It just suddenly didn't come on. I messed with it, and eventually it came back on. Then later it died again. I figured out that slamming the microwave door jiggled something somehow and the LED screen would light back up and everything would work. But then it would go off again. Eventually it just stopped coming on no matter how much I slammed the door!
Mine has the same problems. After removing top cover, check fuse on power supply board (mine was OK). Then check thermo fuse located to the far left under the top cover( 2 black wires going to it) using a meter. I then jumped this fuse to see if this was the only problem. I hope to find a replacement thermofuse at the local hardware store.
Posted on Mar 07, 2009
Micowave goes on for few seconds then blows fuse. replaced magnetron tube and still does same thing
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
See these links:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/xformer.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Apr 05, 2013 | GE Microwave Ovens
GE JES1136WL01 paint chipping inside, is it safe to use?
Safe to use unless it begins sparking. There is special microwave paint available to touch it up.
http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=502509
Eric
Oct 14, 2009 | Microwave Ovens
Help on a micerowave!!
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
Unfortunately, that part is not cataloged for this model.
In fact, the parts catalog says it you have problems with this model, you must return it to the place of purchase!
Not very helpful, but please don't kill the messenger! *grin*
You might try contacting GE to see if they will help.
GE Customer Service is here.
Nov 27, 2008 | GE Microwave Ovens
I have a new microwave oven Model JVM1750SM1SS. Does this model allow me to use seconds rather than minutes. For instance can I place a frozen dinner roll in the oven for twenty seconds?
It should. Normally to cook 20 seconds you would pres COOK TIME - 2 - 0 - START.
You can download your owner's manual free.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 12, 2008 | GE Microwave Ovens
Microwave oven just died
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Once you've looked over the safety warnings, here are some useful links:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Jan 04, 2008 | Microwave Ovens
GE Microwave XL 1800
remove top cover of oven , check fuse and control unit, high voltage section and diodes and capacitor and magnetron,
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Follow up to: Unit shuts off (JVM1340WW002) and blows fuses
In my 20 years of working on microwaves, I have never seen a capacitor fail in any way but a dead short, but it's possible that it's failure may occur in a less abrupt manner. The internal structure of a capacitor is essentially a rolled up sandwich consisting of two thin layers of foil separated by a very thin insulator. While a "perfect" capacitor consumes no power, in the real world, things can happen to change that. A defect could increase the capacitve reactance or other internal resistance and allow internal heat buildup or expansion, which could lead to an intermittent short when it's warmed up a bit. After a while, the short could become permanent - sort of like arc welding, if you're familiar with that. So, while it's quite possible that this is the pathology that lead to a fully shorted capacitor, I think that's what you have, no matter how it happened.
Nov 07, 2006 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
488 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
