Question about Toshiba satellite c660
Trying to remove the lid from a toshiba c660
Have removed the broken screen already and have got a new lid with screen to put back on it but can't remove the old lid
    Top Expert:
  • 5,051 Answers
The lid has to come off. Make sure you remove the strip that is right above the keyboard so that you can get to the screws that hold the lcd in place. Also remove the screws on the bottom of the laptop that are right under the lcd screen. Sometimes there are screws on the back side of the lcd screen that have to be removed.
Posted on Apr 27, 2012
4 Suggested Answers
SOURCE:
  • 317 Answers
SOURCE: Cracked Screen
The backing of the screen will stay. You'll only be receiving the lcd.
http://www.fonerbooks.com/laptop_4.htm
Posted on Mar 08, 2008
hunter19_46m
  • 7482 Answers
SOURCE: hi, I have a toshiba sattelite
Hi thompsona207...
Start your computer in the Safe Mode.
To start in Safe Mode
Turn your computer on
Keep tapping F8 while the computer is starting up
When the computer starts select Safe Mode
1. Uninstall any softwear you may have put on the computer before the problem started.
2. Do a complete System Restore: Start>All Programs>Accessories>System Tools>System Restore.
This will bring your system back to a time before you installed the softwear or Microsoft installed drivers,etc.
Note: Just be sure to use a date in a darkened box before your trouble start date.
When you have done the above, restart the computer and if your still getting the problem, then installed drivers,softwear,etc might have corrupted the Operating System.
If that happened then that means either repair or reinstall the operating system.
You will need to do the following:
1...Repairing the Operating System...
A...You will have to have the Operating Dics that came with the computer.
Note...If you do not have the disks that came with your computer or the ones you should have made when you first got your computer...then you will have to go to the manufacture's webpage and see if they have a recovery disk available for your computer, if they do not a recovery disks available then you can also try ebay to locate the recovery disks.
The original disks will have your product key number that came with the computer, you can also find it on the tower, or under the bottom of your laptop, or maybe the piece of paper that the CD orginally came in may have the number on it.
You can also download a small program and it will tell you your product key number.
Go to the following webpage to download your FREE key finder.
http://www.magicaljellybean.com/keyfinder/
B...You will now insert the disc into the CD/DVD player
C...Restart the computer
D...When the window opens that tells you to press "Any" key, you will press any key you want to press.
E...If you do not receive a message that says "press any key to boot from CD", then then the computer is not ready to boot from a cd.
To correct this problem you will have to go into your computer's Bios and change the computer to boot from a CD.
To get into the Bios, shut the computer off,restart, while the computer is starting up keep tapping F1 as the computer is starting up.
When you are in the Bios, select to boot by CD by moving the cursor with the direction arrows on the keyboard.
Once you have selected to boot by cd the exit and restart the computer...the disc is already in the cd/dvd player.
Your system will then boot from the cd.
F...After a minute or less it should ask you if you want to Quit Repair, or Continue.
You will select Repair this time, but you may have to come back here and select "Install" if the repair does not work.
It will ok the agreement document if it asks you too.
Tap F8 on your keyboard to pass it when ready.
It will ask you if you want to Install, Repair, Delete Partition, or Quit.
Select Repair
Inside the box there will be one or two partitions.
Choose the largest partition.
After you have chosen the largest partition, you will then press the "r" key to start the repair
After the repair is complete, then you will need to restart your computer.
G...Computer Restart
After the repair is complete, shut the computer down (the computer will shut down a few times during the installation of the operating system
that is normal).
Then restart your computer, when the computer restarts it will have a box to put your product key...put the product key in the box and click.
The computer should start up and run as if it was a new computer.
You do not need to re-register
You can now remove the disc.
If this fails to clear your problem then you have a hardware problem.
It could be faulty ram
If you still get the BS (Blue Screen), then you have two choices.
1.Reinstall the entire Operating System and you may have to update some drivers.
This will require you to go back to the start of the repair info and select Install instead of Repair.
2..Take your machine in to have the hardware tested.
Keep in mind that if you do a complete reinstall of the Operating System you will lose all the information on the computer,such as pictures, programs, videos, everything you installed will be gone.
Please take time to rate me four thumbs up
Posted on Sep 08, 2011
SOURCE: boot failled toshiba c660
there are a few things that could have caused this. the easiest solution would be to re-install your OS
Posted on Mar 02, 2012
No screen on laptop
make sure the cable connecting the display to the motherboard is seated properly. Disconnect it and reconnect it.
Mar 30, 2014 | Toshiba satellite c660
Toshiba satellite c660 stuck on windows splash
hi K Smith.
Here are some troubleshooting steps that may help in identifying the issue.
- Start by doing a hard reboot, remove the battery and unplug its AC adapter then press and hold the power button for 20 seconds and see if it will boot up.
- If these will not work remove the HDD then boot it up and see if it will still get stuck at the BIOS screen or not.
- If it doesn't get stuck on BIOS and boot onto a black screen that means it's the HDD that is faulty.
- If it does get stuck on BIOS even without the HDD that means it's the motherboard that is faulty.
- Last trick you can try is to remove the CMOS battery for a second then put it back in.
- If all these will not work you'll need to send it for a repair if its still under the factory warranty
or.
1) Unplug the power cord --> Remove the battery --> Hold the power button for
60 seconds --> Connect the power supply then try to switch ON the laptop and
later put the battery back into the laptop.
2) If the problem still exists then get it checked out.
or read up some more at this link.
Toshiba satellite c660 stuck on windows splash Google Search
Dec 08, 2017 | Toshiba Satellite A135-S4527 Notebook
My laptop screen is not working on satellite c660-2q8
Has their been any damage? Dropped? Will the laptop boot? Fan spins? LED's Blink? Battery Charge light on? Remove ALL media, DVD,CD,USB, unplug, remove battery, plug in , reboot, discribe what happens, anything? Nothing? If the laptop boots and you can see a "ghost image" in a bright light, it may be a switch, if you connect to a external monitor, does it show desktop? Need more info.
Feb 08, 2013 | Toshiba satellite c660
Toshiba satellite c660 not starting up
Do you mean that it wont turn on at all or that it will not boot into Windows.
Try the following ...
Remove the battery and leave the power supply plugged in and try.
Borrow/buy a new/generic power supply see if thats the issue - no power
If you mean windows wont boot successfully you may need to find someone to reinstall Windows on your laptop from the recovery disks/partition
Jan 08, 2013 | Toshiba satellite c660
!!!no reaction on plugging the ac adaptor.!!!
Sound like the LCD screen's inverter is causing an short/overload and the power adapter is shutting down (thermal cutout).
Remove the LCD screen and connect an external monitor, power up the external monitor first and the boot up the laptop. The video should automatically on the external monitor. If the display on the external monitor is OK then the fault could be the inverter which is located at the bottom of the LCD screen between the hinges.
LCD screens and Inverters for your laptop maybe available from this WEB site.www.lcdparts.net
Apr 13, 2012 | Toshiba satellite c660
Middle keys not working
Did you spill a liquid on the keyboard? If not it might be the keyboard cable needs to be reseated or the keyboard is going bad. To reseat the keyboard, close the lid and turn the keyboard over. Remove the screws from the bottom of the keyboard. Some screws might have the keyboard icon on them which means they secure the keyboard. Remove the battery and most times there will be screws inside the battery case and some might have the icon of a keyboard. After you remove the screws from the bottom, turn the laptop back over and open the lid. Use a small flat head screwdriver to pry on end of the strip that is above the top of the keyboard, then the other end (usually the power button is on this strip). Be careful because this strip might have a cable under it. Once your remove the strip there might be screws that are holding the keyboard if so remove them. Now you can lift the keyboard up, but be careful because there is a cable under it. This is the cable that you want to release from the motherboard and then put it back. Usually this cable is secured by a little piece that you can flip up to remove the cable and push it back down once you put the cable back in.
Mar 25, 2012 | Toshiba satellite c660
Toshiba Satellite A135-S2386. Black display.
Inverter probably, but try removing the bezel and check wiring to the inverter and from the screen to the laptop
Feb 09, 2010 | Toshiba Satellite A135-S2386 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Cracked Screen
Mar 08, 2008 | Toshiba Satellite A105-S4004 Notebook
Toshiba satellite c660 Logo
98 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
