Question about Aardvark Direct Pro LX6 Sound Card
Which operational amplifier is good for output of sound card ?
I want use operational amplifier or audio operational amplifier in output of PC sound card,like amplifier of sound card.
    Sergeant:
    Champion:
  • 334 Answers
I use an 80 watt yamaha with sub woofer but there is several good ones out there.There is Logitech, Philips, Bose and J.B.L. that's just a few but these are about the best ones.
In Christ Greg
Posted on Nov 17, 2008
Audio output only out of one output
hello sir,
often this is sound IC fault, if one IC there change it and it will fix the other audio output, as the sound IC have two outputs and one of it doesn't output the audio,
if two sound IC's, it's a must one of it is faulty, you better change both for long run of the audio amplifier
good luck
Oct 18, 2015 | Car Audio & Video
Maudio 192 output
You need the plug/cable that inputs to your mixing desk and outputs from your sound card.
Sep 09, 2008 | M-Audio Audiophile 192 Sound Card
No sound from speakers
You don't mention the sound card(s) in the PC nor the method of connecting to the monitor. Some video cards have HDMI connections for audio and video out to a monitor and will not allow any other audio outputs to work. Regardless of sound source interface, check to be sure that the audio source is the one that is NOT part of your video card and is NOT set to output DIGITAL audio signals.
Once this is done, select the the "add-on" or "expansion slot" sound card (if it is the type that plus into a slot on your motherboard) or the "built-in to the motherboard" type (if the jacks are soldered directly to the motherboard) as the DEFAULT or ENABLED. Set to ANALOG output - NOT digital if a choice is offered. Connect the speakers. This should be via cable terminated with a stereo mini jack - NOT a special digital optical or coaxial cable / connector. Most modern PCs will have several mini-stereo jacks from which to choose - nearly all use the GREEN ringed jack for the FRONT (or main) left & right stereo speakers. Regardless, if yours has GREEN jack, you should use it - if none have a color code, look for markings that indicate either "speakers" ,"output", "front" or "L & R". If there are no indications, check your manual. Set your volume level on the lower side, play an audio source and adjust speaker volume and / or audio mixer settings in the system tray as needed.
Only one sound card will work in a PC. Make sure that all connections are made to the ENABLED card, otherwise no sounds will be heard. Digital output is primarily targeted to facilitate connections to external amplifier and speaker system - most often like those found in a Home Theater PC setting - or a monitor / TV connected by an HDMI cable.
I hope this helps & good luck!
Jun 04, 2013 | Microsoft Windows 7 Home Premium 64BIT...
I think headphone jack output not working is there any other output i can use to send sound to amplifier
yes you can use usb sound card adapter
http://www.ebay.com/itm/USB-SOUND-CARD-AUDIO-ADAPTER-FOR-DESKTOP-LAPTOP-NOTEBOOK-COMPUTER-PC-/160963279451?pt=US_Sound_Card_External&hash=item257a28ba5b
Jan 26, 2013 | HP Pavilion G60-249wm Notebook
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
MY PC SEEMS TO BE PLAYING MUSIC BUT NO SOUND IS COMING OUT
make sure you have a speaker amplifier connected to your pc.audio output...
instal the sound driver for your sound card..
Sep 11, 2011 | Microsoft Windows XP Professional for PC
How to hook up my pc's audio to rca rs3531 to
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level (AUX in your case) input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
http://www.retrevo.com/support/RCA-RS3531-manual/id/19240dj989/t/2/
Jul 26, 2011 | RCA port Turntable with CD&Digital Radio...
Hi,how do I connect up two 5.1 surround sytems to my PC Pavilion m9451ch I know all I need is a 3.5mm RCA jack into the amplifier and connect them up with the outlets on my computer this is OK for one but...
First, you need a sound-card in your computer that is capable of '5.1' operation.
Second, you need a receiver/amplifier that accepts '5.1' input.
This is usually achieved by a "optical digital" output on the computer's sound-card,
an "optical digital' connection cable, and an "optical digital" input on the amplifier.
May 09, 2011 | HP Computers & Internet
Crackling sound on my amplifier
If you have good clean, loud sound with your LP player and not with your PC, your PC is causing the noise. Most PC sound cards are not very HiFi in their sound and it is quite evident when listening to a PC via a HIFI sound. Now, you can not use the headphone outputs to your Pioneer, you must use the LINE OUT jack, set as line out in your computer. There is a signal level mismatch if you use your headphone outs, distorting your Pioneer. Try LINE OUTs or buy a HiFi rated sound card.
Feb 23, 2010 | Audio Players & Recorders
No sound out of the speaker of my lap to dv9000
hi im josh may i he lp you? try this; Sound cards range from simple built-in features to elaborate two-piece devices with physical control panels that mount into a 5 1/4-inch drive bay. The basic purpose of sound cards is to allow the user to hear sounds played by the OS and programs, along with music from audio CDs and other audio files, plus sound from DVD and other types of videos. In addition, these allow for voice communication using software such as Yahoo Messenger, AOL Instant Messenger, and Windows Messenger, along with Internet telephone calls, voice-recognition software, and other uses.
Sound Card Removal and Installation Sound cards are physically installed and removed in the same way as any other card using the same interface (PCI or ISA), except that there are likely to be analog audio cables connected to it inside the computer. On a motherboard with onboard sound, there will also be audio connectors. These connectors are for connecting analog audio to optical drives, modems, and other devices. Some of these connectors are polarized, but even if they aren't, the worst that can happen is that the right and left audio channels could be reversed. Figure 8.4 shows the audio connectors on a sound card.
Figure 8.4: A sound card's audio connectors. External Sound Connections Sound cards can vary as to the number and type of external inputs and outputs. The most basic, usually found on motherboards with built-in sound, have three:
Microphone input: This is for a computer microphone, although battery- powered condenser mics usually work in these jacks.
Line input: This is for an external line source such as a cassette deck or CD player's line outputs.
Speaker/headphone output: This is a headphone-level output that can sometimes drive small, non-amplified speakers. They are usually connected to amplified speakers.
A sound card with a built-in amplifier would have full-power speaker outputs, able to drive most non-amplified speakers. More advanced cards have a whole assortment of inputs and outputs. On many cards, the icons that identify each jack are very difficult to see and interpret, especially when you are struggling just to see any part of the back of the computer. Consult the manufacturer's documentation. Figure 8.5 shows sound card jack panels.
Figure 8.5: A sound card jack panels. Now look carefully at Figure 8.5. The concentric arcs represent sound waves. An arrow pointing toward the center indicates a line input, while an arrow pointing away from the center represents a line output. The microphone and speaker icons are more illustrative than are the others.
Diagnosing and Repairing Sound Problems There are a number of steps you can take to correct sound problems. First, make sure the speakers are powered, turned on, and turned up. Make sure all external connections are correct, and that the cables aren't damaged. Run System File Checker (see Chapter 11). Reinstall the sound drivers. Sometimes, you'll have to remove the device in Device Manager, shut down the computer, remove the card, restart the computer and uninstall any programs that came with the sound card, and then shut down the computer again. Then, follow the manufacturer's directions for installing the card, or just reboot and see if Windows will install it correctly. If you have any trouble with resource conflicts, which would be evidenced by instant lockups, go into the BIOS and make sure Plug and Play is enabled.
Selecting a Sound Card A basic sound card is good for most people. High-end models are good for gamers and musicians. Some people like to have surround sound with their computers, so surround sound models are common.
good luck
Mar 06, 2009 | HP Pavilion dv9000z Notebook
Aardvark Direct Pro LX6 Sound Card Logo
106 people viewed this question
Top Aardvark Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Aardvark Computer and Internet Expert? Answer questions, earn points and help others
