Question about RCA P46924 46" Rear Projection Television
Convergence problem with old rca 46 in rear projection TV
When test pattern is on I can allign the horizontal and vertical lines towards the center but at the ends they are off. The amount they are off is the same right and left as it is up and down. For 12-15 inches it is on the line but the horiz. line at the left is up an inch and down an inch on the right. Same with the vert.
    Genius:
  • 2,920 Answers
You will need to have a shop re converge it or order a new convergence board.
Posted on Nov 17, 2008
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    I have an rca model hd52w67 tv and there is a problem with the picture. the picture has a red and green picture that don't allign by about an inch. I think it is in the picture guns but i cant find a...
    Do not align the guns! they are located facing up toward the mirror; they are picture tubes! covered with big glass lenses! heavy!
    instead look for a red/green/blue adjustment knob on the set's front; the buttons should say: convergence or, crosshatch push the crosshatch button: once you have three vertical lines crossing three horizontal lines; just merge them using the other R/G/B knobs untill you have one white vertical line and, one horizontal line crossing in the center of the screen.
    (you may have to find the controls on the remote using "setup")
    Feb 11, 2010 | RCA Televison & Video
    My Panasonic rear projection TV color is off
    hello it sound like convergance ic might be the trouble it's a big job to do yourself a lot of testing and a lot of desoldering and soldering get a quote from an engineer
    regards
    shaun
    Jan 19, 2010 | Panasonic PT-47WX49 47" Rear Projection...
    My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
    Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
    1. Press action button to enter MENU.
    2. Navigate to SETUP.
    3. Scroll down to CONVERGE.
    4. Press VOL > to select.
    5. Press CH buttons to navigate up or down.
    6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
    7. Press VOL > to select.
    8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
    9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
      center of cabinet.
    10. Press ACTION button to display red center correction screen.
    11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
    12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
    NINE POINT CONVERGENCE CORRECTION
    Remote Control must be in TV mode.
    1. Press ACTION button to display red correction screen.
    2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
    3. Use the navigation buttons to align the RED cross with the white cross pattern.
    4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
    5. To exit press ACTION button repeatedly, then press CH up.
    Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
    Rear Projection TV convergence
    dear friend if you have that type of skills you cerlainly can either resolder or replace the convergence stks. you we'll need to replace both if that's the case. they look like the audio outputs in the audio amplifiers. good luck
    caypianan@yahoo.com
    Oct 12, 2008 | Televison & Video
    TV ALLIGNMENT
    you have bad convergance problems solder bad connections if that dont work then replace the convergance ics
    Nov 03, 2007 | Toshiba 42H81 42" Rear Projection...
    RCA P46924 46" Rear Projection Television Logo
    90 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
