Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Whirlpool LTE6234D Top Load Stacked Washer / Dryer
The washer does not fill there's water coming into the washer it just does not fill i don't know how the water is being pump out at the same time? please advice
  • Anonymous Mar 22, 2014
    margherita 2000
  • 291 Answers
Is your drain hose above the washer tub.. its got to be higher or will syphone out
Posted on Aug 28, 2007
Instead of the washer filling, the water simply runs through and goes down the drain
Check your drain it has to be higher than the water in the machine when full or it will go out the drain. Hope this helps.
Aug 16, 2010 | Whirlpool LTE6234D Top Load Stacked...
Washer not working
Hello, It is most probably either the water valve shut or the hose kinked also check that the drain hose is not blocked also.
Hope this helps.
Thanks
May 23, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE 6234 Washer / dryer
sounds like a failure of the control unit, best to have it checked out by repairer
Feb 02, 2018 | Whirlpool LTE6234D Top Load Stacked...
Water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
Jan 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Wont fill with water
I probably has a bad fill valve or a clogged screen suggest check to see if the fill valve is engaging and if there is water getter past the valve.
Jan 20, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
155 people viewed this question
Sal De
Marvin
Marvin
jimorris77
