Question about HP PSC 2355v All-In-One InkJet Printer
Carriage jam - HP PSC 2355v All-In-One InkJet Printer
  • 2 more comments
  • varunsahay Nov 26, 2008
    my printer HP4110 red light blinking and carriage jam : clear jam, and then press enter is showing on the screen.
    I bought a new black and colour cartridge inserted them in the right places (colour left and black right) and then got this.
    help!
  • slh0701 Dec 21, 2008
    I have a HP OfficeJet 7310 and I am getting the error message carriage jam open door, clear carriage jam then press ok to continue. There doesnt seem to be anything blocking the carriage but I cant get the message to go away. Please help!
  • mlr1974 Dec 22, 2008
    exact same problem. there is nothing visibly jammed anywhere. yet i keep getting the error message carriage jame. open door. clear carriage jame and then press ok. i do all of those things and keep getting the same message.
  • Anonymous Jan 17, 2009
    I have the same problem.  HP 1600 that says it has a carriage jam.  Open door, clear jam, press OK.  I've unplugged it, replugged, etc.  There is nothing jamming the carriage that I can see.  It does scan to my computer, and I did get a color copy of a photo and it seemed OK.  But when I tried to make another copy, and tried to print a document, I got the same  carriage jam message.  HELP!
I had this same problem with an HP2355v. There is a carriage directly below the print heads (on the right side of the printer) where the ink is dumped during the cleaning process. The carriage needs to be able to freely move (fore and aft). I noticed that my carriage was really gummed up on the left side of the carriage. I cleaned the edge of the carriage and the channel where it travels with alcohol and qtips. The carriage now moves with minimal effort and the error is fixed! Good luck.
Posted on Jan 18, 2009
I had the same issue. The IT group for my company no longer supports the HP Officejet 7410 All-in-One, so I decided to monkey around with it myself. Not sure if this will help anyone else, but this is what I did to resolve my issue. Good luck.
1. Turn off and unplug the printer.
2. Lift the head/cover unit and take out the ink cartridges.
3. Manually slide the ink carriage to the left. (Here, I noticed a pool of ink on the bottom where the ink carriage normally rests).
4. Use some tissue and a Dry Erase Board Cleaning fluid (I think Qtips and rubbing alcohol will suffice) and clean out as much of the ink as you can. Please note that there is a piece of sponge at the bottom (that is already built into the printer). You probably don't want to rip out the sponge. Just clean up as much of the ink as you can.
5. Replace the ink cartridges, close the cover, plug in the printer and turn it back on.
After doing so, the error went away and my printer is back to normal.
Posted on Jan 06, 2009
    Problem Solver:
  • 15 Answers
First make sure everything is clear inside and nothing was put in your printer by accident, then unplug everything and plug it back in then restart... hope it works:)
Posted on Nov 17, 2008
I'm getting an error msg and can't print. It says please fix cartridge jam and hit enter. I can't find any jam. What do I do?
If there isn't a cartridge jam then it's probably a carriage jam:
However, I'm not too familiar with clearing a carriage jam. I just know that if your cartridges are not blocked then the carriage is likely at fault. You will need to Google this on how to fix a carriage jam.
Jan 24, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
What is a carriage jam
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on..open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper fromthe roller...return the paper output tray and the carriage access door. plugthe power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriageaccess door.
disconnect the power cord from the back..remove the paper output tray...lookinside if the carriage is stuck and if there is no papers or object that restrictthe carriage to move..return the output tray.. return the carriage accessdoor...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on theprinter..disconnect the power cord from the product..disconnect the power cordfrom the wall outlet.. wait for 15 seconds.. plug the power cord to the wallsocket....plug the power cord at the back of the printer.. press the power onof the printer.. try to print the test page...
http://www.fixya.com/support/t6088190-hp_7400_displayshttp://www.fixya.com/support/t6088190-hp_7400_displays
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 10, 2010 | Office Equipment & Supplies
Carriage jam - Turn machine on, get carriage jam message, however the carriage can move freely if moved by hand. If I close and hit enter, carriage sounds like it's moving, then I get the error message...
Sorry about the B.S., you can move the carriage by hand, and all you need is to clean the encoder strip that runs across behind the carriage assembly. You can wipe the strip gently with an alcohol swab or a Q-tip moist with alcohol. The bars on that strip tell the carriage where it is and grease or ink on it will give the carriage jam error. No calibration necessary after moving the head or cleaning the strip.
Jan 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My HP PHotosmart C4150 is reporting a carriage jam. I have removed all paper , opened the door, and reclosed it. It is not working. I cannot see any carriage jam.
Hi
Please see this link from HP, and check how to clear the carriage jam(link includes the pictures aswell)--
HP Photosmart C4150 Carriage jam Troubleshooting
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | HP Office Equipment & Supplies
Carriage jam
Usually when the printer displays a carriage jam error the carriage assembly is jamming along the carrige path.
There may be something in the carriage path or the carriage shaft may need lubricating.
Check the area where the carriage is has stoped. There might be an obstruction visible.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP PSC 2355v All-In-One InkJet Printer Logo
399 people viewed this question
Seeker5211
Seeker5211
