Question about IBM ThinkPad R31 2656 Notebook
Think pad wont pick up hard drive?
I did a rescue and recover and I didnt know what i was doing.Now it wont pick up the hard drive to install a new OS?
  • chaddyass2 Nov 18, 2008
    From the think vantage blue botton
  • 93 Answers
From where did you do a rescue and recover? From Windows or by press ThinkVantage blue button or by CD?
Posted on Nov 17, 2008
Hard drive does not recognize a file system
Buy a software called EASUS DATA RECOVERY WIZARD, install it on a working computer. Connect your hard drive as a slave and open the program. Use the Complete Recovery Method to recover all your files. It is usually pointless to try and recover system files. Unless you want to recover your documents and files that were there in the hard drive.
Apr 03, 2012 | Iomega Computers & Internet
My nomad zen jukebox is stuck in rescue mode and still not working correctly
If you can boot into the Recovery Mode menu, run the Disk Clean-Up option from there. As long as your drive isn't physically damaged, it should be able to fix your problem.
> You can try the "Clean Up" option in Rescue Mode. - let it run for a few hours, and then try to reformat. if that dosnt resolve it then you know its almost gone.
If the hard drive is mechanically damaged (as it most likely is - the drives used in the Zen Xtra are rather fragile compared with current drives),As for recovering the files from your existing drive then the only possible way to retrieve the data stored on it is to utilize a Data Recovery Service but it will cost you a lot except if still under warranty
you can only replace the hard drive Taking the Zen Xtra apart is rather easy - two screws on the back, and that's it. The Zen Xtra uses a standard laptop hard drive, so it'll be easy to locate and install a new one - just be sure the new hard drive you install has a current rating equal to or less than the current rating for your existing drive. To remove the hard drive, you'll need to pop off the front cover, remove the battery, and remove the four broad-head screws that retain the hard drive in place. Then carefully pry the top end of the hard drive out, and pull it away from the case, pulling from the top end.
When you install the new hard drive, you will need to re-install the firmware.
Sep 11, 2009 | Audio Players & Recorders
Format The ( C ) dirve
nothing can be done now to recover. u just need to reinstall everything again,
Jun 19, 2009 | Acer TravelMate 3260-4874 Notebook
SD CARD ERASED
Is it possible to use some data recovery software such as Photo Rescue Pro to recover the files from your memory card?
Apr 26, 2009 | GPS
Power connection, but no Data (Mac)
The first and simple thing to do is to try a different data cable and see if it works. If it doesn't work then may be it has crashed and you can probably recover it using a recover tool like Recoversoft Data data rescue Pc. Th trial version will let you determine whether you can recover or not. If the differnt cable thing wont work then let me know and i will walk you thru the data recovery process using Recoversoft Data data rescue Pc.
Jul 10, 2008 | FireLite (USBFLB80) Hard Drive
Is there a way to recover lost data from my Western Digital My Book??
Yes, there is a way to recover lost data from a WD drive.
First thing first - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD.
The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more from: http://www.western-digital-data-recovery.com/
Best regards!
Jan 06, 2008 | Western Digital My Book Essential Edition...
Sandisk SD memory card problem
same thing happened to me. I bought a program called search and rescue from Compusa and was able to recover all files and saved to my hard drive. Yes it does sometimes happen to memory cards. How it happened, not sure, but i recovered..good luck art
Mar 15, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
IBM ThinkPad R31 2656 Notebook Logo
70 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
